Newbi what todo
SO,
I have a pinePhone Pro Explorer and the keyboard phone holder.
Firstly. Is there an easy or "recommended" method of removing the Phone from the the keyboard holder??? I was forced to use tweezers and twist them and try and wriggle them behind the phone and in front of the screen bit just to get the phone out. It wasn't easy, and the phone now has scratches on it.
Real Newbie question.
What do I do now??
I REALLY wanted this pine phone so I could seamlessly integrate the phone with my desktop. Abilities to sync emails, copy of phone calls, Voice recordings of VoIP calls, copy of sms & mms, and files.
I don't use social media full stop, and have no intention of ever using it. ScoialMedia just sucks the life out of privacy!
How do I go about Testing things? I am half a point higher than a noob with linux to begin with, but I can search and figure things out. I do like a good problem to solve, as long as I know it's a problem.
SO FYI. Ask me to work out how to change something setting on the phone. My Autistic brain will thank you for it.
Ok. Now I've plugged the phone into the keyboard, and put it on charge.
Now it wont wake up
I am able to turn the volume up and down, but pressing or holding for 5secs either power buttons wont wake up, of make noises, or anything.
Help Please
https://forum.pine64.org/showthread.php?tid=16470
The case has a slot for a knife edge on one of the corners.
Only charge the keyboard.
(09-13-2022, 10:18 AM)mburns Wrote: Only charge the keyboard.
Okay. I fully charged it the other day, removed the phone as I needed access to SD-Card slot, and phone was dead.
Is that Normal?
https://forum.pine64.org/announcements.php?aid=78
https://forum.pine64.org/announcements.php?aid=79
ezik
(07-26-2023, 10:00 PM)shulamy Wrote: https://forum.pine64.org/announcements.php?aid=78
ezik
Yep. Check all that, thanks.
I would also suggest -
Try to connect it - wifi/data/bluetooth - which ever you use
Try setting this device up to get to as close to usable that you need - ie visit websites/access emails/calendar
Then
Find an SD card to try some other distros on
Learn how to reset/reinstall/add programmes/remove programmes etc
Test the sound/download some radio apps etc
Start enjoying it and report problems and successes
1 Now with Pinephone Pro (used to have Pinephone and Pinetab) cooking on Mobian - Seasoned Ubuntu user since 2007
2 Known to break things - often
3 Sometimes known to fix things then see 2 above
Re: prying them apart
I use a thin Jim Dunlop red Tortex guitar pick. The red one is very thin and is pretty flexible. It will not scratch the plastics of the PPP unless you are determined to do so. The guitar pick is easy to carry with my PPP accessories (charger, charging cable, charging cradle for the battery).
