How to get rid of the PIN prompt during reconnection?
Exclamation
Hello
I lose the connection several times a day and I have to enter my PIN code each time to get it back. Please can someone tell me where it can be configured? It's very annoying, I become unreachable for hours when I don't notice the connection has been lost.
Moreover, I often have to turn off and on the mobile data to make them work anew after this prompt, I'd be glad to be able to get rid of this limitation too.
May be
mmcli -i any --pin=1234
as root in a simple crontab/systemd timer will do the job ?
Or in gnome-control-center : Parameters / Network / Sim lock ?
You can disable the pin in gnome-control-center
Mobile Network --> SIM Lock --> Lock SIM with PIN --> off
Exclamation
(09-06-2022, 09:23 AM)jsch Wrote: You can disable the pin in gnome-control-center
I'd like to find something less drastic but thanks. The title of my original post is a bit misleading.
