in search for the /boot/config-...... file
(05-26-2016, 01:49 PM)longsleep Wrote: I just released Kernel 3.10.101-4-pine64-longsleep-51 which has the sound sequencer.
that is fantastic news,
I will try it out right away.
Stupid question: where is it ?
In the image thread I find only the image of 7 may
https://www.stdin.xyz/downloads/people/l...es/ubuntu/
xenial-pine64-bspkernel-20160507-1.img.xz 07-May-2016 20:23 170M
never mind, got it, need to run the update scripts in
http://forum.pine64.org/showthread.php?tid=293
Yes, i do not release image just because there is a new Kernel as Kernel and U-Boot can be easily updated.
well, longsleep ...
A very big thank you for that update.
With that kernel module (sound sequencer) I achieved my goal or project:
connecting a midi sprout (https://www.kickstarter.com/projects/dat...ion-device)
to pine64, and with the packages aconnect, fluidsynth and rosegarden
I'm now able to listen live to midi signals comming from plants and record that midi signal. Cool
Interesting !
(05-27-2016, 11:28 PM)pelgrim Wrote: well, longsleep ...
Can you record in MP3 or FLAC and share with us?
sure thing, just need some time.
I'm still kind of learning how to use the sprout and getting advice on their forum,
plants apparently need their time to adjust to the sticky probes.,
and I have 0 experience as a musician.
So what you will get is the "raw" output of the plant/sprout:
a serie of notes sent through the fluidsynth software, without any kind of fiddling or "production".
I like tubelar bells as output, the output is very clear.
There is a giant mountain of things I need to learn about music software.
(05-29-2016, 03:04 AM)pelgrim Wrote: Here it is, some very raw data.
A recording with video camera, while the midi sprout was converting plant signals to midi signals,
live fed and converted to sound and out of the speakers.
https://youtu.be/XEBYiJkADe4
In the attached zip files:
- a picture of the "tortured" orchid plant probed for signals
- de produced midi recording
The mp3 I produced is too big, even as zip file, I create a snapshot tomorrow if wanted.
.zip   2016_05_29_13_00_Orchid.midi.zip (Size: 11.5 KB / Downloads: 424)
Interesting Wink
Still having fun, with a Sansevieria trifasciata this time
https://youtu.be/4AD_uflC1dw
  Pine 1 will no longer boot (bricked) dstallmo 0 2,313 06-22-2023, 12:22 PM
Last Post: dstallmo
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 4,490 06-10-2019, 12:07 PM
Last Post: pqueiro
  +LTS/SOPINE Compilation procedure for U-Boot and Linux for pineA64 LTS. danpurprakash@gmail.com 1 5,863 06-05-2019, 11:50 PM
Last Post: igorp
  Pine Board using linux stuck during boot sequence ktaragorn 0 4,145 03-23-2019, 04:06 AM
Last Post: ktaragorn
  Resize /Boot mmcblk0p1 on SD? chadc 7 15,662 08-24-2018, 01:23 PM
Last Post: goathunter
  Ubuntu boot very slow with wifi driver remainder 9 25,437 08-03-2017, 07:23 AM
Last Post: victorssantos
  config error installing XML-RPC on longsleep Ubuntu tinkertom 2 6,476 02-22-2017, 06:50 AM
Last Post: MarkHaysHarris777
  Need help with boot options Gnx 1 4,773 01-22-2017, 09:27 PM
  straight boot into desktop Ola 2 5,497 08-01-2016, 11:12 PM
Last Post: Ola
  UBUNTU first boot Clouddead 6 10,000 06-29-2016, 12:40 PM
Last Post: pineacle
