Solutions to modem / connection problems
For people trying to use the Pinephone as a daily driver, the biggest showstopper appears to be the modem with its quirks and crashes.
There are many stories about many problems, sometimes along with workarounds and fixes, spread all over the forum and often difficult to find.
I would therefore like to ask you:
Which modem problems did you have, that -- now comes the important part of the question -- you could solve or minimise and how did you do it?
To answer your question - I haven't resolved any issues with my modem mainly because I haven't really had any!
My main problemette with the modem is (currently) it drops the data connection every couple of hours. On my home network it usually recovers pretty quickly (seconds) - when I am roaming it can be much more painful (5 minutes) and/or need a reboot. As I am usually on my home network it is very much an observation rather than a show stopper.
For completeness I flashed to 01.002 way back
journalctl -b | grep EG25GGBR
Dec 09 21:27:50 mobian eg25manager[509]: Response: [EG25GGBR07A08M2G_01.002.01.002\r\n\r\nOK]
and
uname -a
Linux mobian 5.15-sunxi64 #1 SMP Thu Nov 25 14:39:58 UTC 2021 aarch64 GNU/Linux
(12-09-2021, 03:57 PM)dukla2000 Wrote: To answer your question - I haven't resolved any issues with my modem mainly because I haven't really had any!
i found something, it's not total fix though. https://forum.pine64.org/showthread.php?...#pid103530
shortly: edit file "/usr/lib/udev/rules.d/80-modem-eg25.rules" and change ATTR{power/control}="auto" into ATTR{power/control}="on". tested on manjaro arm linux. most likely will have side effects like wasting battery.
If you have problems sending text messages, this might fix it.
  Latest firmware for PinePhone modem! Subsentient 106 227,499 04-03-2026, 08:37 AM
Last Post: baptx
  Problems with audio via bluetooth connect to car zkajdan 1 5,714 06-18-2024, 12:51 AM
Last Post: qcomment
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 4,378 04-10-2023, 10:19 PM
Last Post: lupyuen
Sad Modem is always visible/connected but stops working after a while dante404 6 7,582 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 6,101 10-25-2022, 05:28 PM
  Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! kop316 201 315,808 03-24-2022, 03:16 AM
Last Post: as365n4
  Problem Flashing the modem Firmware loreson 0 2,415 12-22-2021, 10:31 AM
Last Post: loreson
  bluetooth connection to car multimedia interface problems (no sound) zkajdan 0 2,008 10-29-2021, 01:34 AM
Last Post: zkajdan
  Python3 Bridge SMS/MMS to Matrix using Modem Manager and MMSD FutureBucket 3 6,692 02-10-2021, 08:09 PM
Last Post: kop316
  Remote connection from Linux Mobile to unrooted Android? (surely very useful?!) 4w7gvrvsjcyvd 0 3,196 01-30-2021, 06:48 PM
Last Post: 4w7gvrvsjcyvd
