Spotify
The Spotify application for Linux is working perfectly fine on my Manjaro Plasma desktop, but neither Spotify Web Player nor the app is available for the Manjaro Plasma Mobile right out of the box. Has anyone found a smooth solution to get it working?
spot-client in the aur
I can recommend the 'spot' app, you can install it following the instructions at the bottom of: https://flathub.org/apps/details/dev.alextren.Spot
Beforehand you may have to install flatpak itself, check https://flatpak.org/setup/ for instructions or just enter
sudo pacman -S flatpak
I tried other spotify implementations before, the flathub/flatpak way work the fastest for me with almost no pain Smile
(09-30-2021, 03:39 AM)lacriz Wrote: Hi,
The lack of podcast support is a deal breaker
