Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now)
I've been setting up my Rockpro64 with a Manjaro-ARM-minimal-rockpro64-21.08.img that I DLed a while ago. The built-in ethernet worked.
After upgrading the system via pacman, it does not work.
Old kernel: 5.13.12-1-MANJARO-ARM
New kernel: 5.14.1-1-MANJARO-ARM
Or possibly the new linux-firmware 20210818.c46b8c3-1.
If I connect a random USB ethernet dongle, that works fine.
But with the built-in port, nothing gets through. Pinging my PBP makes the lights on its dongle flash, but absolutely nothing shows up in Wireshark running on it. The ARP pings apparently aren't comprehensible.
Anybody want to test & confirm? Or is it just me?
Edit 09.17 (Fri)
The update to kernel 5.14.2-1-MANJARO-ARM a couple of days ago fixed it.
Not just you, ethernet was broken for all rk3399 boards in 5.14. Not sure why it hasn't been reverted yet.
See https://lore.kernel.org/linux-rockchip/Y...ashalap/T/
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
In the Manjaro kernel, a fix for that problem was added as of 2021-09-07.
The contents are the same as CounterPillow pointed out above.
"add patch to hopefully fix ethernet on rk3399"
https://gitlab.manjaro.org/manjaro-arm/p...e64c3646ad
  Freezes and kernel panics with Debian trixie jssfr 4 3,393 04-15-2026, 06:48 PM
Last Post: prahal
  [Manjaro] Fixing /etc/fstab from serial console while using lvm2 Dendrocalamus64 0 1,005 10-16-2025, 05:58 PM
Last Post: Dendrocalamus64
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 5,747 09-22-2023, 04:27 AM
Last Post: diederik
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 6,423 06-16-2023, 10:54 AM
Last Post: CounterPillow
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 4,308 05-08-2022, 03:26 PM
Last Post: paralin1
  Kernel OOPs triggered by big writes to ext4 FS ajtravis 1 4,068 04-04-2022, 05:29 PM
Last Post: ajtravis
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,756 02-17-2022, 12:10 PM
Last Post: flounder
  CPU Fan Won’t Turn On in Manjaro publiclewdness 0 2,251 12-31-2021, 12:51 AM
Last Post: publiclewdness
  compiling a new kernel for overclocking on arch Mentaluproar 2 5,493 07-15-2021, 10:16 AM
Last Post: Mentaluproar
  Other boot options than Sdcard for linux 5.x kernel? MisterA 2 6,124 07-14-2021, 02:37 PM
Last Post: TRS-80
