How to play audio from ffmpeg?
(08-30-2023, 04:01 PM)Kevin Kofler Wrote: Well, open up a volume control GUI (on Plasma Mobile, it is in the settings under "Audio", I don't know where it is on Phosh) and check that the earpiece is not muted and that its volume is not zero. Normally, if you set a reasonable volume once, it should remember it next time you switch to the earpiece. Though I have seen various volume control bugs resetting some volumes to zero for whatever reason, so I cannot promise that it will not end up back at zero at some point in the future.
The sound problems were present in the stable version dated 2023-06-10. :-)
https://images.mobian.org/pinephone/
The problems were with Mobian and earpiece and speaker.
After installing the dated version from 2023-08-27, everything works as it should.
https://images.mobian.org/pinephone/weekly/
  Modem audio settings jack1 2 4,011 02-04-2023, 04:01 PM
Last Post: jack1
  3.5mm jack audio quality? orbital 3 6,956 06-27-2022, 02:05 AM
Last Post: wibble
  scratchy phone audio KABA 3 6,243 06-24-2021, 01:15 PM
Last Post: jameslauren11
  Audio quality GloriousCoffee 5 12,252 10-24-2020, 12:00 PM
Last Post: GloriousCoffee
