New use case for my Pine64
(05-16-2020, 05:01 AM)Tharadash Wrote: Hi S265
Unfortunately, although stated as supported by the fedora arm-image-installer, Rock64 is not "officially" supported.
See this bug report:
https://pagure.io/arm-image-installer/issue/52
Ok thanks for that update.
(05-16-2020, 07:40 AM)tophneal Wrote: Armbian will still work in the role as a small server. In fact, it can help you install several services/apps from Softy withing its armbian-config tool.
Software support comes into play with server. I immediately ran into a problem trying to install Webmin on the Arm system.
Re Fedora. Recently updated to Release 32 on my Pine64 where it has been running for 24 months or so. It has been very good. Unfortunately it cannot be repeated on the Rock64. I see some users have been looking at usb boot, also some discussion on uboot. Not sure if that my be used in the future.
New use case for my Pine64 - by S265 - 05-15-2020, 08:47 PM
RE: New use case for my Pine64 - by Tharadash - 05-16-2020, 05:01 AM
RE: New use case for my Pine64 - by S265 - 05-16-2020, 05:22 PM
RE: New use case for my Pine64 - by tophneal - 05-16-2020, 07:40 AM
RE: New use case for my Pine64 - by S265 - 05-22-2020, 02:13 AM
Lightbulb NAS + ​Pine64 ROCK64 = Few Important Questions FilipWozniak 8 14,397 04-14-2019, 09:21 AM
Last Post: default_user8
  Slow SMB Transfer speed.Sent multiple email to Pine64 website and No single reply avelec 3 4,770 03-13-2019, 06:10 AM
Last Post: PatrickM
  C++ GPIO seg fault on Rock64 using Pine64-CPP Jeff R 1 3,459 02-06-2019, 07:40 PM
Last Post: Jeff R
  Docker-CE on a Pine64 amarbl 3 8,150 10-16-2018, 05:52 AM
Last Post: maumoura
  High quality metal case incoming :) Luke 8 9,770 08-25-2018, 07:53 PM
Last Post: jsfrederick
