What is the highest usable DRAM clock speed for you?
552
29.17%
7
564
0%
0
576
12.50%
3
588
8.33%
2
600
4.17%
1
612
8.33%
2
624
37.50%
9
24 vote(s)
[Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes
#78
@Luke I now know how to fix this. It had to do with the version string I used.
I'm currently rebuilding.
@daniel This topic primarily came about because I noticed my phone getting unstable with higher memory clocks (at the time default clock speeds had changed in some distributions). Using a slower memory clock will consume less power and therefore should make your phone cooler (this is the OS independent part). This is probably why you got directed to this post. OS dependent: The temperature at which the CPU will be throttled is 70 degrees Celsius for Mobian as far as I know. UT probably has a lower setting -> hence it being cooler.
In plain words: To change the clock speed you need to use a flash a patched bootloader (u-boot is widely used and is - among other things - responsible for setting the memory clock speeds).
For mobian you can install a debian package as instructed in the OP. (But please wait until tomorrow when I have updated the links).
For other distributions I have an idea how to get the binary which you can flash using "dd", but I haven't yet build them/tried it
RE: [Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes - by devrtz - 07-25-2020, 05:49 PM
  emmc speed via usb? joe1 0 60 04-27-2024, 08:07 PM
Last Post: joe1
  Phone powers off with high user demands car46999 7 689 04-11-2024, 09:17 AM
Last Post: zetabeta
  Help needed: Jump drive not working UsnR2 5 5,024 07-09-2021, 03:22 PM
Last Post: UsnR2
  Endless crashes on Pine64 received today luciphercolors 4 5,626 11-24-2020, 06:09 PM
Last Post: rocket2nfinity
  Does the PinePhone have a hardware random number generator? LibrePhoneUser 4 6,371 11-12-2020, 07:47 PM
Last Post: megous
  Only enable modem when needed with kill switches sokolgeo 2 4,135 09-20-2020, 04:40 AM
Last Post: sokolgeo
Sad Crashes in every OS - Hardware-issue? rakor 4 6,194 06-22-2020, 09:20 AM
Last Post: Nooblife
