What is the highest usable DRAM clock speed for you?
552
29.17%
7
564
0%
0
576
12.50%
3
588
8.33%
2
600
4.17%
1
612
8.33%
2
624
37.50%
9
24 vote(s)
[Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes
#56
(07-07-2020, 04:41 AM)Luke Wrote: @devrtz do the instructions in OP still work in newer builds / nightlies?
Flashed more than one PinePhone and always end up with white LED and no boot.
For reference:
sudo dd if=u-boot-sunxi-with-spl-600.bin of=/dev/sdg bs=8k seek=1
I just flashed the latest image I had built (492MHz) and it boots with the instructions from the OP. Do you have a serial connection handy to check where it hangs?
You may want to try this image:
https://fortysixandtwo.eu/upload/u-boot-...pl-492.bin
It is the latest one I built. But be aware that deep sleep didn't seem to be working for me.
Sidenote:
I think "u-boot-install-sunxi64" should be used nowadays to update u-boot in mobian. Not sure if you can just replace the binary in
"/usr/lib/u-boot/pinephone/u-boot.bin" then run "u-boot-install-sunxi64 /dev/XXX" and have it working..
Maybe I should look into building a .deb file. I think in this case the postinstall scripts take care of everything!
RE: [Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes - by devrtz - 07-07-2020, 07:48 AM
  emmc speed via usb? joe1 0 73 04-27-2024, 08:07 PM
Last Post: joe1
  Phone powers off with high user demands car46999 7 705 04-11-2024, 09:17 AM
Last Post: zetabeta
  Help needed: Jump drive not working UsnR2 5 5,032 07-09-2021, 03:22 PM
Last Post: UsnR2
  Endless crashes on Pine64 received today luciphercolors 4 5,636 11-24-2020, 06:09 PM
Last Post: rocket2nfinity
  Does the PinePhone have a hardware random number generator? LibrePhoneUser 4 6,403 11-12-2020, 07:47 PM
Last Post: megous
  Only enable modem when needed with kill switches sokolgeo 2 4,146 09-20-2020, 04:40 AM
Last Post: sokolgeo
Sad Crashes in every OS - Hardware-issue? rakor 4 6,209 06-22-2020, 09:20 AM
Last Post: Nooblife
