What is the highest usable DRAM clock speed for you?
552
29.17%
7
564
0%
0
576
12.50%
3
588
8.33%
2
600
4.17%
1
612
8.33%
2
624
37.50%
9
24 vote(s)
[Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes
#32
(05-23-2020, 03:20 PM)dukla2000 Wrote: I added memtest=17 in /boot/boot.cmd
but clearly that isn't what is being used at boot
/boot/boot.cmd can be seen as the source code, and /boot/boot.scr the "compiled" version, which is the one actually used by u-boot (at least that's how it's done on Mobian, but afaik it's the same on other OS'es)
It can be generated using the following command:
mkimage -T script -A arm64 -C none -n pinephone -d /boot/boot.cmd /boot/boot.scr
RE: [Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes - by a-wai - 05-23-2020, 03:52 PM
  emmc speed via usb? joe1 0 60 04-27-2024, 08:07 PM
Last Post: joe1
  Phone powers off with high user demands car46999 7 688 04-11-2024, 09:17 AM
Last Post: zetabeta
  Help needed: Jump drive not working UsnR2 5 5,024 07-09-2021, 03:22 PM
Last Post: UsnR2
  Endless crashes on Pine64 received today luciphercolors 4 5,626 11-24-2020, 06:09 PM
Last Post: rocket2nfinity
  Does the PinePhone have a hardware random number generator? LibrePhoneUser 4 6,371 11-12-2020, 07:47 PM
Last Post: megous
  Only enable modem when needed with kill switches sokolgeo 2 4,135 09-20-2020, 04:40 AM
Last Post: sokolgeo
Sad Crashes in every OS - Hardware-issue? rakor 4 6,194 06-22-2020, 09:20 AM
Last Post: Nooblife
