Xposed works! More or less. How To: Manually install Xposed Framework
The flashfire method unfortunately does not work for me.
1. Latest Android Build, Rooted with Busybox.
2. Latest zip from http://dl-xda.xposed.info/framework/sdk22/arm64/
3. Flashfire program runs correctly and pine reboots.
4. Xposed apk installed.
5. The framework is present but not installed - Not compatible with SDK22 or Armv8a.
6. Above method has worked fine with other boards, tablets and phones.
RE: Xposed works! More or less. How To: Manually install Xposed Framework - by Morbid42 - 07-11-2016, 02:35 AM
  Battery Issues - Nothing Else Works mesaxi 3 4,685 07-25-2017, 06:53 PM
Last Post: mesaxi
  Is there an android tv image out there where I can install netflix? eclay 2 6,420 07-18-2017, 08:49 AM
Last Post: eclay
  Faulty lcd screen? Wrong install process? Help! Krinilssen 4 6,353 06-14-2016, 09:29 PM
Last Post: janjwerner
  Manually resizing SD partition atoomic 1 3,979 01-30-2016, 02:02 PM
Last Post: patrickhwood
  OS INSTALL? timmyiscool8 8 10,509 01-28-2016, 04:20 PM
Last Post: frodo_loves_metal
