Xposed works! More or less. How To: Manually install Xposed Framework
I installed Xposed using the FlashFire method (the Play Store link worked for me) and it worked a treat.
My reason for installing it was that I've found that certain apps expect a Wifi connection to be present to work, but I'm using an ethernet connection for my Pine 64. The following module will tell configured apps that Wifi is present so they'll work with ethernet too:
http://repo.xposed.info/module/com.lemon...connection
RE: Xposed works! More or less. How To: Manually install Xposed Framework - by simmo - 06-06-2016, 05:02 AM
  Battery Issues - Nothing Else Works mesaxi 3 4,650 07-25-2017, 06:53 PM
Last Post: mesaxi
  Is there an android tv image out there where I can install netflix? eclay 2 6,378 07-18-2017, 08:49 AM
Last Post: eclay
  Faulty lcd screen? Wrong install process? Help! Krinilssen 4 6,308 06-14-2016, 09:29 PM
Last Post: janjwerner
  Manually resizing SD partition atoomic 1 3,950 01-30-2016, 02:02 PM
Last Post: patrickhwood
  OS INSTALL? timmyiscool8 8 10,442 01-28-2016, 04:20 PM
Last Post: frodo_loves_metal
