LTS will not boot with 7" LCD connected
Just received my A64 LTS with Playbox and 7" LCD from Pine after many delays (another story). Very excited!
My LTS boots fine (eMMC) with Armbian Buster and an HDMI monitor connected. I'm powering via the supplied 5V/3A barrel connector ps. However with the LCD DSI cable attached, the LTS will not boot - the green power light comes on, dims slightly, then goes out after a couple of seconds.
It seems I'm not the only one with this issue:
https://forum.armbian.com/topic/8392-pin...ment-95229
Quote:After plugging everything together I inserted the DC barrel jack (original 5V 3A power supply) and then the LED goes on only for 1-2 seconds and then goes off.
Does this seem like a hardware issue? On that discussion, someone mentioned a similar issue until they used a swapped out the A64 board.
LTS will not boot with 7" LCD connected - by GregH - 03-11-2020, 09:49 PM
