terminal command for sd card size
I'm looking for the same thing.
I have no computer, replaced it with a smartphone over a decade ago, even then it was Win95,98,XP followed by about six months of Ubuntu and thanks to Synaptic Package Manager, I only used the terminal maybe half a dozen times. A record I beat with the Pinephone simply by turning it off ($ sudo poweroff) as I can't find any other way.
I thought I found the solution with parted ($ sudo parted) I think it came preinstalled, unless it was installed as a dependency by something else I installed. I'm assuming these operations need administrator privileges.
In parted I tried the print command which revealed partition 2 was what I probably wanted to resize.
Then I used the resizepart command and then entered 2.
It then prompted me for an end size, with the current size in brackets, something like [1120MB] I entered 14GB
Then I entered the print command again, which revealed the resized partition.
I tried again, but entered 200GB (it's a 256GB sdcard) which failed. Disk /dev/mmcblk2 evidently is the 16GB emmc storage.
I assume the command: select /dev/mmcblk? would get me on the right track, what is the microsdcard labelled as in postmarketos on a Pinephone?
terminal command for sd card size - by pnphn - 02-22-2020, 03:03 AM
RE: terminal command for sd card size - by Danny - 03-03-2020, 08:27 AM
RE: terminal command for sd card size - by Danny - 03-04-2020, 05:39 AM
  How can I get the permissions to write to the external SD card ...? Peter Gamma 10 9,436 06-16-2024, 02:36 PM
Last Post: Peter Gamma
  How to create a file on the SD card I can modify on my Ubuntu PC? Peter Gamma 0 1,865 06-16-2024, 02:33 PM
  How to write the the external SD card with Abword? Peter Gamma 0 2,326 08-27-2023, 01:10 AM
  How can I open an Abiword file from an external SD card with Abiword? Peter Gamma 5 6,061 08-25-2023, 02:05 AM
  Help how to mount SD-Card chadwick 8 15,622 11-30-2021, 11:12 PM
Last Post: chadwick
  Terminal password difficulty Hobbes42 2 5,193 10-18-2020, 08:24 AM
Last Post: Hobbes42
  PP boots into factory test even if flashed sd card is inserted hapster 5 9,789 04-13-2020, 02:34 PM
Last Post: MartijnBraam
  terminal application disappeared from app drawer (pmos+phosh) nieral 5 10,645 03-31-2020, 01:58 PM
Last Post: Seferi
  Root FS partition size Zweitaktmotor 1 3,976 02-12-2020, 06:03 PM
Last Post: dukla2000
