Anyone seeing occasional display stuttering?
(04-29-2016, 05:34 AM)hyperlogos Wrote: Actually I am seeing the whole OS stutter. Everything chokes periodically.
Do you know why every Android device out there uses eMMC? Since eMMC shows pretty decent random I/O performance.
Do you know what happens if you use an average SD card with Android? The symptoms you describe above.
Random I/O is the key and SD cards of the same 'speed class' differ here by factor 20 or even more: http://forum.armbian.com/index.php/topic...rformance/
Unfortunately the 'speed class' ratings used for SD cards don't tell anything about random I/O and it's also not that easy to measure this in Android/RemixOS (with Linux you would use iozone for example -- see the aforementioned link)
RE: Anyone seeing occasional display stuttering? - by tkaiser - 04-29-2016, 05:43 AM
  display problem florianl 6 6,971 06-11-2016, 10:12 AM
Last Post: kiko
  turn off display after inactivity Blindstealer 3 4,840 06-05-2016, 05:18 AM
Last Post: dkryder
  Display too large for TV slamminsalmon 1 2,768 04-04-2016, 10:54 PM
Last Post: arpanj2
  How to turn off and wake up display? JulianM 19 22,119 02-02-2016, 10:44 PM
Last Post: SkimMilk
