official software project ? (Rust for IOT ?)
Hi All: I'm here (the writer of that long PineTime article), so glad the forum is still alive :-)
Here's the build size as of today, which includes the Rust driver touch controller...
+ newt size -v nrf52_my_sensor
Size of Application Image: app
Mem FLASH: 0x8000-0x42000
Mem RAM: 0x20000000-0x20010000
 FLASH     RAM
   799     299 *fill*
   228       0 apps_my_sensor_app.a
  2302       0 crypto_tinycrypt.a
   401       0 encoding_base64.a
   948       0 encoding_json.a
   440     444 hw_bsp_nrf52.a
    52       0 hw_cmsis-core.a
   154       0 hw_hal.a
  6806     154 hw_mcu_nordic_nrf52xxx.a
     2       0 hw_sensor_creator.a
  1516     256 hw_sensor.a
  8546    8220 kernel_os.a
  2562      50 libc_baselibc.a
   298       0 libs_mynewt_rust.a
 56133     402 libs_rust_app.a
 13400       0 libs_rust_libcore.a
   736      42 libs_semihosting_console.a
   974     225 libs_sensor_coap.a
  1157     209 libs_sensor_network.a
   677     212 libs_temp_stub.a
  2397     394 net_oic.a
 35496    2103 nimble_controller.a
  4026    1209 nimble_drivers_nrf52.a
 44242    2785 nimble_host.a
  1814     648 nimble_host_store_config.a
   692    1096 nimble_transport_ram.a
   712      42 sys_config.a
   334     128 sys_flash_map.a
     2       0 sys_log_modlog.a
   686      29 sys_mfg.a
    30       5 sys_sysinit.a
   120       0 util_mem.a
   164       0 nrf52_my_sensor-sysinit-app.a
   166       0 libg.a
   808       0 libgcc.a
objsize
  text    data     bss     dec     hex filename
189780     352   18200  208332   32dcc /Users/Luppy/mynewt/stm32bluepill-mynewt-sensor/bin/targets/nrf52_my_sensor/app/apps/my_sensor_app/my_sensor_app.elf
Current ROM size is 189 KB, that's less than half of the 512 KB total available ROM. What's taking up the ROM?
libs_rust_app.a (56 KB): This is the Rust application + third-party (non-system) Rust libraries, including the Embedded Graphics library. The large size is probably due to the font embedded in the library.
nimble_host.a (44 KB): This is the NimBLE Bluetooth Stack host code that runs the Bluetooth iBeacon logic. (Similar to Nordic SoftDevice)
nimble_controller.a (35 KB): This is the NimBLE Bluetooth Driver code for the nRF52 2.4 GHz transceiver. (Similar to Nordic SoftDevice)
libs_rust_libcore.a (13 KB): This is the Rust Core Library. System functions needed by Rust.  Similar to stdlib and stdio.
Rest of the code is from the Mynewt OS, written in C.
So right now the Bluetooth Stack (written in C) is actually a little bigger than the combined Rust code. And the Rust code is bloated really because of the graphical UI.
In any case, we still got plenty of ROM space to use. I think eventually we should offload the font data to the SPI Flash memory (8 MB)
About the Bootloader and Doing Direct Firmware Upgrade (DFU) via Bluetooth...
I'm now using a Stub Bootloader. It doesn't do anything, it just jumps to the Application Code.
The proper bootloader to use is MCUboot (also used in Zephyr OS). It supports swapping of Application Code Images and can rollback in case of problems. Which means we need to store 2 copies of the Application Code: Old (before upgrade) and New (after upgrade).
How shall we fit 2 copies of Application Code into 512 KB ROM? We could offload the font data and other graphical assets into the SPI Flash (8 MB). Any user-developed Watch Apps that run on top of the system Rust Application could also be offloaded to the SPI Flash.
Or we could store both copies of Application Code into the SPI Flash. Which means the bootloader will need to overwrite the ROM by SPI Flash during upgrades and rollback. More work for the bootloader.
Or we could upgrade PineTime from nRF32832 to nRF52840 to double the ROM size (1 MB!). This makes PineTime more expensive of course.
Application Code Images are digitally signed to ensure they are authentic, so it's possible to receive Application Code updates via Bluetooth.
About the Assembly Code generated by the Rust Compiler...
The Rust Compiler generates Assembly Code that's surprisingly readable, almost like C! (I browse the Assembly Code sometimes to check for performance issues)  Check this out...
https://github.com/lupyuen/stm32bluepill...2143-L3018
This Assembly Code corresponds to this Rust code for rendering the UI...
https://github.com/lupyuen/stm32bluepill...s#L44-L145
That disassembly was generated by "objdump" from the compiled Rust ".o" files. The Rust Compiler generates machine code that's as clean as the C Compiler, no function prologues and epilogues.
This is the same machine code that goes into the actual PineTime Firmware.  Here's the "objdump" disassembly of the PineTime nRF52 Firmware, look at lines 22030 to 22872...
https://github.com/lupyuen/stm32bluepill...030-L22827
Another example: Here's an Interrupt Handler written in Rust:
https://github.com/lupyuen/stm32bluepill...rs#L72-L80
And here's the "objdump" disassembly of the compiled ".o" file:
https://github.com/lupyuen/stm32bluepill...#L861-L899
About Static vs Dynamic Memory Allocation...
I'm also a stubborn believer that all memory in embedded devices should be Statically Allocated, budgeted way in advance. (And if we didn't budget enough, it's our fault!)
The Rust code I have written is based on the "[no_std]" convention: No heap, no dynamic memory allocation ("Box"), no standard library for String() support (which uses heap).
Which causes some pain because some Rust libraries insist on using the "[std]" convention with heap support. So you see this weird code below for formatting numbers as strings... The write!() macro insists on using a heap-based string for storing the formatted output. Thus we fake it by passing an "arrayvec::ArrayString", which comes from an external library that uses a fixed-size array ("buf_x") to simulate a heap-based string...
From https://github.com/lupyuen/stm32bluepill...s#L98-L123
/// Display the touched (X, Y) coordinates
pub fn show_touch(x: u16, y: u16) -> MynewtResult<()> {
   //  Format coordinates as text
   let mut buf_x = ArrayString::<[u8; 20]>::new();
   write!(&mut buf_x, "  X = {}  ", x)
       .expect("show touch fail");
   let text_x = fonts::Font12x16::<Rgb565>
       ::render_str(&buf_x)
       .stroke(Some(Rgb565::from((0xff, 0xff, 0xff))))  //  White
       .fill(Some(Rgb565::from((0x00, 0x00, 0x00))))    //  Black
       .translate(Coord::new(40, 100));
   //  Render text to display
   unsafe {
       DISPLAY.draw(text_x);
RE: official software project ? (Rust for IOT ?) - by lupyuen - 11-20-2019, 12:19 AM
  Article: Create Your Own PineTime Watch Face in Rust... And Publish on crates.io lupyuen 2 5,475 10-18-2020, 09:24 PM
Last Post: lupyuen
  Rust on PineTime at RIOT Summit lupyuen 3 5,749 09-25-2020, 05:05 PM
Last Post: lupyuen
  Article: Porting PineTime Watch Face from C to Rust On RIOT with LVGL lupyuen 0 2,297 09-12-2020, 10:13 PM
Last Post: lupyuen
  Developing the software in the web browser kreyren 2 3,095 03-10-2020, 01:34 PM
Last Post: VMMainFrame
  Create PineTime Watch Apps with Visual Rust lupyuen 0 2,114 02-19-2020, 02:50 AM
Last Post: lupyuen
