Battery discharge curve
(11-22-2019, 04:26 AM)pfeerick Wrote: Schematic suggests a single colour LED, dunno what colour, so no dual colour indication there!
http://files.pine64.org/doc/PineTime/Pin...191020.pdf
If there is an LED, it is not visible from the outside. I tried to toggle pin 27 and saw nothing...
Quote:Conceptually, it just measures the voltage using the ADC on pin 31 (AIN7) with the following settings:
  • reference voltage: internal (0.6V)
  • gain set to 1/5
  • positive/negative channel resistors bypassed
  • acquisition time 3µs
  • single ended mode
Thanks @ayke  for these info, I've successfully measured the battery voltage with these.
I've measured max voltage of more than 4v, a bit more than what you show on your graph.
How should we use your discharge curve to display the battery level in % ? For now, I implemented a simple linear interpolation between 3.9v and 3.55. Anything above 3.9 is 100%, anything lower is 0%. Is there a smarter way to process the voltage?
Thanks!
Working on InfiniTime, the FOSS firmware for the PineTime: https://github.com/InfiniTimeOrg/InfiniTime
Mastodon : https://mastodon.codingfield.com/@JF
Twitter : https://twitter.com/codingfield
Matrix : @JF002:matrix.org
Battery discharge curve - by ayke - 10-30-2019, 04:04 AM
Battery discharge curve - by maiden - 10-30-2019, 04:23 AM
RE: Battery discharge curve - by ayke - 10-30-2019, 04:40 AM
RE: Battery discharge curve - by maiden - 10-30-2019, 05:57 AM
RE: Battery discharge curve - by caligari - 10-30-2019, 06:34 AM
RE: Battery discharge curve - by aritual - 09-20-2020, 10:44 AM
Battery discharge curve - by maiden - 10-30-2019, 07:17 AM
RE: Battery discharge curve - by caligari - 10-30-2019, 05:35 PM
RE: Battery discharge curve - by ayke - 10-30-2019, 07:35 AM
Battery discharge curve - by maiden - 10-30-2019, 05:46 PM
RE: Battery discharge curve - by pfeerick - 11-22-2019, 04:26 AM
RE: Battery discharge curve - by JF002 - 12-31-2019, 08:11 AM
RE: Battery discharge curve - by pfeerick - 01-02-2020, 02:33 AM
RE: Battery discharge curve - by JF002 - 01-02-2020, 04:33 AM
RE: Battery discharge curve - by pfeerick - 01-03-2020, 04:18 AM
RE: Battery discharge curve - by geoffrey.vl - 05-02-2020, 07:32 AM
