Use Audiojack instead of HDMI audio
(04-28-2016, 12:11 PM)pictus Wrote: Does this disable HDMI audio at all, or can i switch between HDMI and Audiojack?
I´m a little bit scared of running this, and then have no sound at all.
It changes nothing to HDMI audio as HDMI audio is built into the Kernel. How you switch output devices depends on the software you use. If you use a desktop with pulseaudio use pavucontrol (probably have to install it).
(04-28-2016, 12:11 PM)pictus Wrote: When i remove "/etc/modules-load.d/pine64-audiojack.conf" if its not working, is it reseted to the defaults?
Sure - after all its not Windows or Mac OS.
Use Audiojack instead of HDMI audio - by pictus - 04-27-2016, 12:45 PM
RE: Use Audiojack instead of HDMI audio - by longsleep - 04-28-2016, 12:16 PM
RE: Use Audiojack instead of HDMI audio - by Luke - 04-29-2016, 07:13 PM
lenny, help with audio jack - by rahlquist - 04-28-2016, 11:35 AM
RE: lenny, help with audio jack - by baryluk - 04-28-2016, 04:21 PM
RE: lenny, help with audio jack - by rahlquist - 04-28-2016, 09:27 PM
RE: lenny, help with audio jack - by tllim - 04-28-2016, 04:41 PM
  +LTS/SOPINE Audio Jack Pinout Little_Johnny 0 3,053 12-29-2019, 08:44 AM
Last Post: Little_Johnny
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 3,142 01-24-2019, 07:00 AM
Last Post: ecolezen
  PINE64 STEREO AUDIO DAC POT jtgiroux 0 3,217 01-12-2019, 04:56 PM
Last Post: jtgiroux
  Sound quality from audio jack devanl 0 3,329 10-11-2017, 10:39 PM
Last Post: devanl
  Audio Extractor Ralck 1 4,553 05-25-2017, 12:25 PM
Last Post: dkryder
  Using the pine64 with AVR - HDMI pass-through Moshe.Vazan 4 6,237 01-02-2017, 02:58 PM
Last Post: Moshe.Vazan
  HDMI touch screen not detected Radio 2 4,666 09-29-2016, 06:42 AM
Last Post: Luke
