Any way to run 32-bit apps?
Quote:You can do either option: run either 32bit Linux, or install support for 32bit ARM executables.
My suggestion would be the latter. On Debian or Ubuntu based systems, I believe it should be as simple as running
sudo dpkg --add-architecture armhf
Alternatively, you could find some of the old "armhf" OS images for the Pinebook, but again I do not recommend that.
Thanks for your response.  The OS that comes with the new Pinebook is a version of Ubuntu then?
Should
work fine with the OS that comes with the laptop?  :-)
-Carl Gundel, author of Liberty BASIC
http://www.libertybasic.com
http://libertybasiccom.proboards.com
Any way to run 32-bit apps? - by CarlGundel - 07-09-2019, 11:50 AM
RE: Any way to run 32-bit apps? - by fire219 - 07-09-2019, 01:58 PM
RE: Any way to run 32-bit apps? - by CarlGundel - 07-09-2019, 02:31 PM
  Tool chain to write Pine 64 linux apps on a Windows Dev machine SvdSinner 2 5,836 07-17-2017, 11:37 PM
