PhoenixCard Burning Error
(04-22-2016, 08:19 PM)alin123 Wrote:
(04-22-2016, 04:31 PM)tllim Wrote:
(04-22-2016, 02:22 PM)alin123 Wrote:
(04-22-2016, 12:12 AM)tllim Wrote:
(04-21-2016, 07:23 PM)alin123 Wrote: I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple times
We start release Android, Remix and Linux build images that can be burned by DD method.
Where can i find instructions for the DD method?
Already posted at http://wiki.pine64.org/index.php/Pine_A6...re_Release.
We plan to make this page better understandable on next few days.
It says to use phoenixcard for Remix OS. Also I couldn't find the DD method, which tab is it under?
Hi, have you tried Linux Live USB Creator ? http://www.linuxliveusb.com/downloads/?stable
PhoenixCard Burning Error - by alin123 - 04-21-2016, 07:23 PM
RE: PhoenixCard Burning Error - by tllim - 04-22-2016, 12:12 AM
RE: PhoenixCard Burning Error - by alin123 - 04-22-2016, 02:22 PM
RE: PhoenixCard Burning Error - by tllim - 04-22-2016, 04:31 PM
RE: PhoenixCard Burning Error - by alin123 - 04-22-2016, 08:19 PM
RE: PhoenixCard Burning Error - by androsch - 04-22-2016, 12:25 AM
RE: PhoenixCard Burning Error - by cookeys - 04-23-2016, 12:49 PM
RE: PhoenixCard Burning Error - by alin123 - 04-24-2016, 02:34 PM
RE: PhoenixCard Burning Error - by cookeys - 04-24-2016, 03:18 PM
RE: PhoenixCard Burning Error - by Keex - 04-25-2016, 12:02 AM
RE: PhoenixCard Burning Error - by ententeak - 05-06-2016, 04:51 AM
RE: PhoenixCard Burning Error - by blktiger - 05-22-2016, 02:05 PM
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 4,102 04-19-2019, 08:26 AM
Last Post: psychedup
