Video Blurry
It's because the HDMI output seems to be defaulting to the defined BaseDisplayInfo settings for the "Built-in Screen" which has a resolution of 1024x600. I'm assuming this is the native resolution for the PINE64 7" LCD display that this build mentions in the release notes. I was able to change the resolution by opening an ADB shell and then running the wm size command followed by the desired resolution. In my case it looked like this:
rk3399_mid:/ $ wm size 1920x1080
Obviously you can change the desired resolution to match your display's native resolution and orientation.
Curiously, there is a defined "HDMI Screen" that is set to 1920x1080. I wonder if the interfaces were mixed up and users who connect the 7" display to the DSI/eDP ribbon will be see nothing since their 1024x600 screen will be trying to output 1080p.
Video Blurry - by Hailstrom - 02-05-2019, 08:39 AM
RE: Video Blurry - by b0lshevik - 02-06-2019, 06:45 AM
RE: Video Blurry - by tllim - 02-06-2019, 08:12 PM
RE: Video Blurry - by kardanadm - 03-07-2019, 08:04 AM
RE: Video Blurry - by joek - 04-06-2019, 12:17 PM
RE: Video Blurry - by vprofx - 04-09-2019, 06:45 PM
RE: Video Blurry - by NightCrawler504 - 04-10-2019, 11:29 AM
RE: Video Blurry - by tllim - 04-15-2019, 04:20 PM
RE: Video Blurry - by kardanadm - 06-15-2019, 02:16 AM
RE: Video Blurry - by NightCrawler504 - 04-23-2019, 05:38 PM
