USB fails to power device?
(12-11-2018, 02:42 PM)BackWoodsTech Wrote: One thing I am wondering is if there's a default setting for the USB 2.0 that's trying to mount the device rather than charge it? I guess that makes no sense.
Could be - but you should see noise in the system log then if the "presented" USB device is changing (dmesg or journalctl).
(12-11-2018, 02:42 PM)BackWoodsTech Wrote: UPDATE: the device does say 5v 2A.
Most likely an absolute max that is theoretical and never reached. But does indicate >500mA very likely, and thinking back to your OP (boot, shutdown, repeat) does tend to say it is almost OK, gets to a point where it cant get enough power so shuts down ...
lsusb -v reports what power a USB device is limited to: I am sure a very crude measure on USB 2 ports but if you run the router on the USB 3 port then it may be a bit more useful. (My DVB stick in a USB2 port says 500mA - it is a USB2 device and so is clearly happy running somewhere under 500mA but no idea how much under. My Bluetooth dongle only asks for 100mA.)
But bottom line I figure you should use the power adapter.
USB fails to power device? - by BackWoodsTech - 12-08-2018, 03:09 PM
RE: USB fails to power device? - by evilbunny - 12-08-2018, 06:48 PM
RE: USB fails to power device? - by BackWoodsTech - 12-09-2018, 06:49 AM
RE: USB fails to power device? - by evilbunny - 12-10-2018, 12:48 AM
RE: USB fails to power device? - by BackWoodsTech - 12-10-2018, 07:17 PM
RE: USB fails to power device? - by evilbunny - 12-10-2018, 07:47 PM
RE: USB fails to power device? - by BackWoodsTech - 12-11-2018, 05:49 AM
RE: USB fails to power device? - by dukla2000 - 12-11-2018, 01:23 PM
RE: USB fails to power device? - by BackWoodsTech - 12-11-2018, 02:42 PM
RE: USB fails to power device? - by dukla2000 - 12-11-2018, 06:29 PM
RE: USB fails to power device? - by BackWoodsTech - 12-12-2018, 02:47 PM
RE: USB fails to power device? - by fosf0r - 12-12-2018, 03:18 PM
RE: USB fails to power device? - by BackWoodsTech - 12-13-2018, 07:26 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,071 04-01-2024, 10:24 PM
Last Post: nano2
  RP64 Won't Boot After Power Down ColPanic_ 10 7,843 06-27-2023, 07:31 AM
Last Post: dkebler
  NAS Setup: Hdds PSU external power option Robotik 1 1,735 07-18-2022, 10:10 PM
Last Post: zer0sig
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,919 04-01-2022, 11:25 AM
Last Post: ashleymills
  Power In Via DC Out actionhank 0 1,306 01-28-2022, 09:45 AM
Last Post: actionhank
  How to add an external power button? foresto 6 9,155 02-05-2021, 10:38 PM
Last Post: foresto
  NAS mods: external serial port and power button foresto 4 6,572 10-04-2020, 11:21 PM
Last Post: zer0sig
  Power Supply - Barrel length Wiing 2 3,613 09-20-2020, 12:38 AM
Last Post: Wiing
  PCI Express x4 Device Support machinevault 4 7,437 07-13-2020, 01:32 PM
Last Post: pgwipeout
  Problems with maskrom OTG USB in Linux - Device not responding to setup address nutilius 0 1,775 08-31-2019, 11:40 AM
Last Post: nutilius
