11-23-2018, 10:30 AM
(11-21-2018, 07:57 PM)evilbunny Wrote:(11-21-2018, 07:29 PM)eclay Wrote: Hello, I have purchased the following external usb enclosure. I've installed a seagate 4TB sata disk.
https://www.amazon.com/gp/product/B01NCM...UTF8&psc=1
I can see this device when I plug it into my laptop but get nothing when I plug it into my pine64. The enclosure has it's own power cable to power it up. dmesg shows nothing about a usb drive/device being connect. I'm running dietpi on my pine64. I've also tried to connect it to my pinebook 14" running xenial mate.
Code:root@DietPi:~# lsusb
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@DietPi:~# ls /dev/sd*
ls: cannot access '/dev/sd*': No such file or directory
My question is should this work attached to a pine64?
You should look for errors if you run 'dmesg' or in `tail /var/log/syslog`
Thanks for the suggestion. There must of been an Id10T error most likely involved here. It's working now.
