Intel I350 T4 problem
My I350 T4 don't work.
rock64@rockpro64v2_1:~$ uname -a
Linux rockpro64v2_1 4.4.132-1081-rockchip-ayufan-g50be7e64a779 #1 SMP Tue Jul 31 20:09:25 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
modul igb is loaded
rock64@rockpro64v2_1:~$ lsmod
Module                  Size  Used by
zram                   32768  6
lz4_compress           16384  1 zram
rockchip_saradc        16384  0
igb                   196608  0
ip_tables              24576  0
x_tables               32768  1 ip_tables
autofs4                40960  0
phy_rockchip_pcie      16384  0
midgard_kbase         651264  0
dw_hdmi_i2s_audio      16384  0
[    4.549919] igb: loading out-of-tree module taints kernel.
[    4.555899] systemd[1]: Starting Create Static Device Nodes in /dev...
[    4.559370] Intel(R) Gigabit Ethernet Linux Driver - version 5.3.5.18
[    4.559372] Copyright(c) 2007 - 2018 Intel Corporation.
rock64@rockpro64v2_1:/dev$ dmesg | grep -E pcie
[    0.504094] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie-regulator[0]' - status (0)
[    0.504145] reg-fixed-voltage vcc3v3-pcie-regulator: Looking up vin-supply from device tree
[    0.504185] vcc3v3_pcie: supplied by dc_12v
[    0.504249] vcc3v3_pcie: 3300 mV
[    0.504403] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 3300000uV
[    2.561326] vcc3v3_pcie: disabling
[    2.855361] phy phy-pcie-phy.9: Looking up phy-supply from device tree
[    2.855385] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed
[    2.857300] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    2.857306] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    2.857345] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    2.857793] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    2.858002] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[    2.858012] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[    2.858051] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    2.858058] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[    2.858067] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[    2.858085] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    2.858186] rockchip-pcie f8000000.pcie: invalid power supply
[    3.358237] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    3.365798] rockchip-pcie: probe of f8000000.pcie failed with error -110
Some hints for me?
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
Intel I350 T4 problem - by tvoegeli - 07-29-2018, 11:46 AM
RE: Intel I350 T4 problem - by jerry110 - 07-29-2018, 11:37 PM
RE: Intel I350 T4 problem - by tvoegeli - 07-30-2018, 05:41 AM
RE: Intel I350 T4 problem - by Arglebargle - 08-09-2018, 11:52 PM
RE: Intel I350 T4 problem - by tvoegeli - 08-15-2018, 09:54 AM
RE: Intel I350 T4 problem - by Bullet64 - 08-15-2018, 09:07 AM
  Posible manufacturing problem with Premium Aluminum Casing. commiecam 0 948 09-09-2022, 10:47 AM
Last Post: commiecam
  usb3 ethernet problem LMM 1 2,147 06-06-2021, 03:21 AM
Last Post: LMM
  OpenWRT + Intel I350-T4 + 1x1 Dual Band WIFI pi64 0 2,039 11-17-2020, 04:25 AM
Last Post: pi64
  Has anyone used an Intel Solid-State Drive 660p Series with the RockPro64? erols 1 3,068 08-25-2019, 05:12 PM
Last Post: Atch
  Hardware problem, Initialisation and Reset superpat 3 5,229 06-21-2018, 03:14 AM
Last Post: pfeerick
