Supported speed of sdcard?
Information
It seems that allwinner chips interface to the sd-card is limited to either 16MB/s (in the sunxi-kernels) and
23MB/s max of 50Mhz 4bit bus on the mainline as stated at
https://forum.armbian.com/topic/954-sd-c...rformance/
To overcome the max 23MB/s  interface to the block device (the sd-card) of the Pine64, which I expect to have an impact on the overall performance as IO often seems the bottleneck, I have looked for alternatives
The Pine 64+ fastest interface seems to be Gigabit Internet, which yields a max about ~110 to 125MB/s. I have therefore run some tests wie nbd (network block device, see https://www.thegeekstuff.com/2009/02/nbd...art-guide/ )
after loading the module
modprobe nbd
and installing nbd-client userspace tool I can attach to a block device hosted on another computer via
ndb-client <ip-of-other-computer> <port> /dev/nbd0
Doing a performance test comparison we get
htparm -t /dev/mmcblk0
/dev/mmcblk0:
Timing buffered disk reads 34MB in 3.01 seconds = 11.31 MB/sec
htparm -t /dev/nbd0
/dev/nbd0:
Timing buffered disk reads 314MB in 3.00 seconds = 104.62 MB/sec
which I hope will improve performance somewhat.
Does anybody know if the ethernet in the A64 is parallel, separate (sort of DMA), or will network access eat CPU cycles?
Supported speed of sdcard? - by humanitypeace - 07-09-2018, 11:57 AM
RE: Supported speed of sdcard? - by humanitypeace - 07-09-2018, 03:10 PM
  improve web browsing speed adamjedgar 0 1,893 02-22-2017, 07:58 PM
Last Post: adamjedgar
