Status PCIe slot and the SATA interface card
#20
(05-28-2019, 12:47 AM)Nikolay_Po Wrote: vecnar, the buying of different controller is good idea. A man in Russia already changed ASMedia controller for Marvell. But first of all, check how hot is ASMedia chip on your SATA board. May be a heatsink on SATA controller will improve an operation.
Hello Nikolay,
It is definitely not heat as it happens when box is off for a long time and issue occurs on first boot when pluging in power supply in the socket on the wall. I read your posts on another thread about it and excluded it. I have a cheap infrared thermometer and it was showing at the start 24 degrees celsius and  32 degrees after beeing on for around 10 minutes. When trying to copy light amounts of files the same temperatures are reported.
I would really want to know what stable revision of sata card is reported to be stable and known to work reliably. It could have been that i received wrong part and it would benefit others having this information somewhere.
RE: Status PCIe slot and the SATA interface card - by vecnar - 05-28-2019, 08:32 AM
  AW-CM256SM wifi card mtek 4 2,424 10-30-2023, 12:00 PM
Last Post: diederik
  Which SATA card should I use my NAS server RAID5 Louysa 3 929 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 576 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 451 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 1,588 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 26,019 12-18-2022, 06:25 PM
Last Post: heyghoge
  PCIe bifurcation support (on RK3399) Arn 1 1,358 11-28-2022, 05:12 PM
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 1,394 12-31-2021, 12:53 AM
Last Post: publiclewdness
  Existings disks and using a StarTech SATA Controller jkugler 1 2,107 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,543 11-27-2021, 11:38 PM
Last Post: Cerberus
