Status PCIe slot and the SATA interface card
(06-12-2018, 07:35 AM)Yoast Wrote: Thanks for the info! Do you remember where you saw the report of a working SATA card?
Frank (Bullet64?) mentioned it on his site - https://frank-mankel.org/post/170 - but it probably came from the IRC chat.
A little later - (I had yet to boot the rockpro64 this morning so held off posting till I had) - I tried the SATA card on 0.6.51, and no luck, so thought I'd try what Frank hinted at in his post about changing the jumpers so changed them and tried again, and it now does appear in the lspci listing at last. No drives connected, and no light on the card, but making progress. Smile Before lspci -t was giving me "-[0000:00]-" and nothing on a -vvv. So something strange going on there with what appears to be simply a socket redirect. Either that, or I got the rockpro64 on a good boot. It's a unstable tempermental beast at times... seems fine once it boots... but sometimes its a 50/50 whether it boots or crashes during bootup.
pfeerick@rockpro64:~$ lspci -t
-[0000:00]---00.0-[01]----00.0
pfeerick@rockpro64:~$ lspci -vvv
00:00.0 PCI bridge: Rockchip Inc. RK3399 PCI Express Root Port Device 0100 (prog-if 00 [Normal decode])
    Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort+ <TAbort+ <MAbort+ >SERR+ <PERR+ INTx-
    Latency: 0
    Interrupt: pin A routed to IRQ 238
    Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
    I/O behind bridge: 00000000-00000fff
    Memory behind bridge: fa000000-fa0fffff
    Prefetchable memory behind bridge: 00000000-000fffff
    Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
    BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
        PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
    Capabilities: <access denied>
    Kernel driver in use: pcieport
01:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02) (prog-if 01 [AHCI 1.0])
    Subsystem: ASMedia Technology Inc. ASM1062 Serial ATA Controller
    Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Interrupt: pin A routed to IRQ 237
    Region 0: I/O ports at <unassigned> [disabled]
    Region 1: I/O ports at <unassigned> [disabled]
    Region 2: I/O ports at <unassigned> [disabled]
    Region 3: I/O ports at <unassigned> [disabled]
    Region 4: I/O ports at <unassigned> [disabled]
    Region 5: Memory at fa010000 (32-bit, non-prefetchable) [disabled] [size=512]
    [virtual] Expansion ROM at fa000000 [disabled] [size=64K]
RE: Status PCIe slot and the SATA interface card - by pfeerick - 06-12-2018, 07:07 PM
  AW-CM256SM wifi card mtek 4 2,372 10-30-2023, 12:00 PM
Last Post: diederik
  Which SATA card should I use my NAS server RAID5 Louysa 3 917 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 568 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 447 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 1,580 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,940 12-18-2022, 06:25 PM
Last Post: heyghoge
  PCIe bifurcation support (on RK3399) Arn 1 1,347 11-28-2022, 05:12 PM
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 1,388 12-31-2021, 12:53 AM
Last Post: publiclewdness
  Existings disks and using a StarTech SATA Controller jkugler 1 2,092 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,524 11-27-2021, 11:38 PM
Last Post: Cerberus
