slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#96
(11-23-2020, 04:24 PM)mara Wrote: this is a bit weird when using the image.
what image did you use.
yeah, you installed bind separately, so you also need to install the library data.
The image I am using is kernel 4.4.241 base.
As I recall, I didn't install bind separately, the nslookup command is already there.
And, which library data is needed for nslookup to work?
Edit: Right now, to fix the development environment is more urgent for me.
Edit1: Just tested nslookup with the 4.9.y base image, the same error message appeared.
RE: Slackware for Rock64 RK3328 - by Luke - 03-18-2018, 03:22 PM
RE: Slackware for Rock64 RK3328 - by mara - 03-24-2018, 02:55 PM
RE: Slackware for Rock64 RK3328 - by mara - 03-30-2018, 06:12 PM
RE: Slackware for Rock64 RK3328 - by tllim - 04-02-2018, 09:50 PM
RE: Slackware for Rock64 RK3328 - by ansic - 04-07-2018, 10:39 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-07-2018, 11:47 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-11-2018, 12:28 PM
RE: Slackware for Rock64 RK3328 - by vincentrock - 04-12-2018, 07:59 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-12-2018, 09:35 PM
RE: Slackware for Rock64 RK3328 - by vincentrock - 04-13-2018, 12:58 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-13-2018, 09:23 AM
RE: Slackware for Rock64 RK3328 - by polpek - 04-14-2018, 02:16 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-14-2018, 09:16 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-14-2018, 12:04 PM
RE: Slackware for Rock64 RK3328 - by polpek - 04-15-2018, 10:39 PM
RE: Slackware for Rock64 RK3328 - by pineadmin - 04-26-2018, 12:22 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-28-2018, 01:27 PM
RE: Slackware for Rock64 RK3328 - by valarauca - 04-28-2018, 05:03 PM
RE: Slackware for Rock64 RK3328 - by mara - 04-29-2018, 12:06 AM
RE: Slackware for Rock64 RK3328 - by vincent37 - 04-29-2018, 12:49 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-29-2018, 03:21 AM
RE: Slackware for Rock64 RK3328 - by pfeerick - 04-29-2018, 03:53 AM
RE: Slackware for Rock64 RK3328 - by pfeerick - 04-29-2018, 03:12 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-29-2018, 06:50 AM
RE: Slackware for Rock64 RK3328 - by vincent37 - 04-29-2018, 02:21 PM
RE: Slackware for Rock64 RK3328 - by mara - 05-08-2018, 02:39 PM
RE: Slackware for Rock64 RK3328 - by vincent37 - 05-12-2018, 01:07 AM
RE: Slackware for Rock64 RK3328 - by mara - 05-12-2018, 03:38 AM
RE: Slackware for Rock64 RK3328 - by vincent37 - 05-15-2018, 02:41 AM
RE: Slackware for Rock64 RK3328 - by mara - 05-15-2018, 09:53 AM
RE: Slackware for Rock64 RK3328 - by pineadmin - 05-21-2018, 01:43 AM
RE: Slackware for Rock64 RK3328 - by mara - 05-21-2018, 08:45 AM
RE: Slackware for Rock64 RK3328 - by mara - 05-25-2018, 04:08 PM
RE: Slackware for Rock64 RK3328 - by mara - 07-01-2018, 07:07 AM
RE: Slackware for Rock64 RK3328 - by ansic - 07-01-2018, 11:06 PM
RE: Slackware for Rock64 RK3328 - by mara - 07-02-2018, 09:36 AM
RE: Slackware for Rock64 RK3328 - by mara - 07-02-2018, 12:32 PM
RE: Slackware for Rock64 RK3328 - by mara - 07-07-2018, 12:44 AM
RE: Slackware for Rock64 RK3328 - by mara - 07-22-2018, 12:54 PM
RE: Slackware for Rock64 RK3328 - by 1of7 - 07-31-2018, 04:10 PM
RE: Slackware for Rock64 RK3328 - by pineadmin - 08-03-2018, 01:30 AM
RE: Slackware for Rock64 RK3328 - by mara - 09-01-2018, 07:27 PM
RE: Slackware for Rock64 RK3328 - by pineadmin - 09-25-2018, 01:08 AM
RE: Slackware for Rock64 RK3328 - by mara - 10-29-2018, 12:36 PM
RE: slarm64 Rock64 RK3328 (aarch64) - by mara - 11-02-2018, 01:41 PM
RE: slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) - by Enig123 - 11-23-2020, 05:31 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 156 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,374 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 340 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 623 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 616 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,455 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 597 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 654 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,488 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 941 08-29-2022, 01:22 PM
Last Post: ramprasad
