slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#56
(07-08-2019, 01:50 PM)KarlF Wrote:
(07-02-2019, 08:16 PM)pineadmin Wrote: Updated Slackware Aarch64 Miniroot (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer.
Updated Slackware Aarch64 XFCE (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer.
I installed the XFCE version. The system hung repeatedly. The first two times during initial start-up, when resizing the sd card, than later on when the mouse was moved in the XFCE session. I think I tried the Miniroot version, too, that also hung. I tried different sd cards to make sure that was not an issue. I used etcher to install the image.
I used to have a  PC-based slackware router that I wanted to reimplement on the rock64. Unfortunatelly, I had to go with Armbian stretch at the end, because I could not use slackware, but I would like to go back to slackware if possible. How stable/reliable slackware on the rock64? Have you had good feedback? I'll try the next release. When will you have it?
Thanks,
Karl
Please ensure the Micro SD Card is UHS-1 class. If used lower class such as Class 2 Micro SD Card is too slow to use and can get the whole system runs in to low performance or sometimes crash.
Thanks,
pineadmin....
RE: Slackware for Rock64 RK3328 - by Luke - 03-18-2018, 03:22 PM
RE: Slackware for Rock64 RK3328 - by mara - 03-24-2018, 02:55 PM
RE: Slackware for Rock64 RK3328 - by mara - 03-30-2018, 06:12 PM
RE: Slackware for Rock64 RK3328 - by tllim - 04-02-2018, 09:50 PM
RE: Slackware for Rock64 RK3328 - by ansic - 04-07-2018, 10:39 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-07-2018, 11:47 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-11-2018, 12:28 PM
RE: Slackware for Rock64 RK3328 - by vincentrock - 04-12-2018, 07:59 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-12-2018, 09:35 PM
RE: Slackware for Rock64 RK3328 - by vincentrock - 04-13-2018, 12:58 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-13-2018, 09:23 AM
RE: Slackware for Rock64 RK3328 - by polpek - 04-14-2018, 02:16 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-14-2018, 09:16 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-14-2018, 12:04 PM
RE: Slackware for Rock64 RK3328 - by polpek - 04-15-2018, 10:39 PM
RE: Slackware for Rock64 RK3328 - by pineadmin - 04-26-2018, 12:22 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-28-2018, 01:27 PM
RE: Slackware for Rock64 RK3328 - by valarauca - 04-28-2018, 05:03 PM
RE: Slackware for Rock64 RK3328 - by mara - 04-29-2018, 12:06 AM
RE: Slackware for Rock64 RK3328 - by vincent37 - 04-29-2018, 12:49 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-29-2018, 03:21 AM
RE: Slackware for Rock64 RK3328 - by pfeerick - 04-29-2018, 03:53 AM
RE: Slackware for Rock64 RK3328 - by pfeerick - 04-29-2018, 03:12 AM
RE: Slackware for Rock64 RK3328 - by mara - 04-29-2018, 06:50 AM
RE: Slackware for Rock64 RK3328 - by vincent37 - 04-29-2018, 02:21 PM
RE: Slackware for Rock64 RK3328 - by mara - 05-08-2018, 02:39 PM
RE: Slackware for Rock64 RK3328 - by vincent37 - 05-12-2018, 01:07 AM
RE: Slackware for Rock64 RK3328 - by mara - 05-12-2018, 03:38 AM
RE: Slackware for Rock64 RK3328 - by vincent37 - 05-15-2018, 02:41 AM
RE: Slackware for Rock64 RK3328 - by mara - 05-15-2018, 09:53 AM
RE: Slackware for Rock64 RK3328 - by pineadmin - 05-21-2018, 01:43 AM
RE: Slackware for Rock64 RK3328 - by mara - 05-21-2018, 08:45 AM
RE: Slackware for Rock64 RK3328 - by mara - 05-25-2018, 04:08 PM
RE: Slackware for Rock64 RK3328 - by mara - 07-01-2018, 07:07 AM
RE: Slackware for Rock64 RK3328 - by ansic - 07-01-2018, 11:06 PM
RE: Slackware for Rock64 RK3328 - by mara - 07-02-2018, 09:36 AM
RE: Slackware for Rock64 RK3328 - by mara - 07-02-2018, 12:32 PM
RE: Slackware for Rock64 RK3328 - by mara - 07-07-2018, 12:44 AM
RE: Slackware for Rock64 RK3328 - by mara - 07-22-2018, 12:54 PM
RE: Slackware for Rock64 RK3328 - by 1of7 - 07-31-2018, 04:10 PM
RE: Slackware for Rock64 RK3328 - by pineadmin - 08-03-2018, 01:30 AM
RE: Slackware for Rock64 RK3328 - by mara - 09-01-2018, 07:27 PM
RE: Slackware for Rock64 RK3328 - by pineadmin - 09-25-2018, 01:08 AM
RE: Slackware for Rock64 RK3328 - by mara - 10-29-2018, 12:36 PM
RE: slarm64 Rock64 RK3328 (aarch64) - by mara - 11-02-2018, 01:41 PM
RE: slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) - by pineadmin - 07-08-2019, 08:26 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 158 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,377 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 345 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 630 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 621 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,487 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 601 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 657 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,647 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 941 08-29-2022, 01:22 PM
Last Post: ramprasad
