SOPine modules stay off at reboot?
If you don't need the actual RTC backup functionality and you want to avoid applying hardware modifications to your Clusterboard, you could connect an external regulated 3.3 V DC power supply to the two pins of the battery holder, with a mandatory Schottky diode "inside" the "+" wire that connects the "+" of the external power supply to the "+" pin of the battery holder.  The purpose of the additional diode is to ensure that no current will flow from the PMICs on the SOPine modules into the external power supply, which would be really bad.
Even in this case, you'd need to solder two wires to the battery holder pins, or to somehow affix the wires reliably to the battery terminals inside the battery holder.
RE: SOPine modules stay off at reboot? - by mdmbc - 02-23-2019, 09:19 AM
RE: SOPine modules stay off at reboot? - by Pine - 03-31-2021, 01:43 PM
RE: SOPine modules stay off at reboot? - by Pine - 04-14-2021, 03:30 PM
RE: SOPine modules stay off at reboot? - by Pine - 04-20-2021, 07:13 PM
RE: SOPine modules stay off at reboot? - by Pine - 04-21-2021, 02:28 AM
RE: SOPine modules stay off at reboot? - by poVoq - 04-06-2021, 06:47 AM
RE: SOPine modules stay off at reboot? - by poVoq - 04-20-2021, 05:35 PM
RE: SOPine modules stay off at reboot? - by dsimic - 04-20-2021, 05:48 PM
RE: SOPine modules stay off at reboot? - by poVoq - 04-21-2021, 11:16 AM
RE: SOPine modules stay off at reboot? - by poVoq - 04-23-2021, 06:21 PM
RE: SOPine modules stay off at reboot? - by renze - 07-22-2021, 05:33 PM
RE: SOPine modules stay off at reboot? - by renze - 08-17-2021, 11:11 AM
RE: SOPine modules stay off at reboot? - by renze - 07-23-2021, 05:41 PM
  Selling Clusterboard + 4 sopine xblack86 7 5,974 09-26-2022, 03:09 AM
Last Post: poVoq
  Buy Cluster and Compute Modules jpotter 1 1,859 01-10-2022, 04:01 PM
Last Post: dcdc
  Clusterboard/Modules shipment arrived in a bag ichibon-brosan 2 5,028 07-09-2020, 12:27 PM
Last Post: shadowhelo
  sopine socket power problem cgiraldo 1 3,335 06-17-2020, 02:10 PM
Last Post: cgiraldo
  Individual SOPINE Power On After Shutdown? Pine 2 3,887 01-30-2019, 08:04 AM
Last Post: mdmbc
  How much force does it take to insert a SOPINE module? jbobspants 0 1,979 01-17-2019, 12:15 PM
Last Post: jbobspants
  Compiling on the Sopine Cluster khaosgrille 3 5,532 08-10-2018, 06:17 AM
Last Post: khaosgrille
  Kubernetes on SoPine cluster part.1 maya.b 3 7,809 04-18-2018, 08:31 AM
Last Post: PigLover
  sopine cluster thermal images maya.b 4 6,803 12-29-2017, 02:51 PM
Last Post: Luke
