Stock Android 7.0 release
(03-06-2018, 02:14 AM)Luke Wrote:
(03-05-2018, 09:38 PM)nkoeppel Wrote:
(03-05-2018, 03:47 PM)Luke Wrote:
(03-05-2018, 03:35 PM)nkoeppel Wrote:
(03-05-2018, 02:58 AM)Luke Wrote: @nkoeppel PhoenixCard is just an Allwinner installer thing. I haven't tried, but I'm sure the images are the same.
@CoMcE whats the native resolution of your display ?
I tried it, it seems the same, remember to use PhoenixCard 4 and not 3, 3 is unreliable.
I replaced /system/priv-app/GmsCore with the /system/priv-app/PrebuiltGmsCore from the zidoo ota and play services works pretty well.
Could you rip the image and share it please ? - would much appreciate it as I'd need it for testing. Don't have windows.
Sounds like it'll be identical to the 16gb image but i can link it tomorrow if you like.
Sorry, misunderstood what you wrote; I thought you got the Zidoo firmware to run on the board. Thanks.
nah, the zidoo won't work on pine, best stick with the pine kernel
actually not sure if it'll replace the kernal but the zidoo ota will replace the bootloader and if you don't have the allwinner setup like the orangepi h6's and have a pine with say a 4GB dram module it will be configured wrong and fail to boot. I suppose you could be crafty and figure out where the bootloader is and flash it back but i think it's not worth the effort. Only thing zidoo has going for it is a working play store which you can just pull off of it like I mentioned earlier and supersu binaries and daemon preloaded. It shouldn't be long before someone sets up an image with root so might as well just wait or try and root it myself. The install script for the flashable supersu packages are very well commented and you can do it all manually.
Stock Android 7.0 release - by tllim - 03-01-2018, 12:40 AM
RE: Stock Android 7.0 release - by CoMcE - 03-04-2018, 05:17 AM
RE: Stock Android 7.0 release - by tllim - 03-05-2018, 08:13 PM
RE: Stock Android 7.0 release - by nkoeppel - 03-04-2018, 02:00 PM
RE: Stock Android 7.0 release - by Luke - 03-05-2018, 02:58 AM
RE: Stock Android 7.0 release - by jaydmiller - 03-05-2018, 08:05 AM
RE: Stock Android 7.0 release - by tllim - 03-05-2018, 08:14 PM
RE: Stock Android 7.0 release - by jaydmiller - 03-06-2018, 03:15 PM
RE: Stock Android 7.0 release - by CoMcE - 03-05-2018, 11:58 AM
RE: Stock Android 7.0 release - by Luke - 03-05-2018, 02:53 PM
RE: Stock Android 7.0 release - by CoMcE - 03-05-2018, 03:16 PM
RE: Stock Android 7.0 release - by nkoeppel - 03-05-2018, 03:35 PM
RE: Stock Android 7.0 release - by Luke - 03-05-2018, 03:47 PM
RE: Stock Android 7.0 release - by nkoeppel - 03-05-2018, 09:38 PM
RE: Stock Android 7.0 release - by Luke - 03-06-2018, 02:14 AM
RE: Stock Android 7.0 release - by nkoeppel - 03-06-2018, 12:59 PM
RE: Stock Android 7.0 release - by Luke - 03-06-2018, 03:58 PM
RE: Stock Android 7.0 release - by Luke - 03-07-2018, 09:41 AM
RE: Stock Android 7.0 release - by constantius - 05-01-2018, 05:04 AM
RE: Stock Android 7.0 release - by pfeerick - 05-19-2018, 09:41 PM
RE: Stock Android 7.0 release - by constantius - 05-19-2018, 12:21 AM
RE: Stock Android 7.0 release - by pineadmin - 05-16-2019, 03:29 AM
  Android 9 soock image ? nrgizer79 0 2,866 01-07-2021, 06:17 AM
Last Post: nrgizer79
  Will there be Android 9.0 for H64 model A? Pepe 2 5,206 04-19-2020, 06:29 AM
Last Post: Pepe
  Updated Android PineH64? msalony101 6 10,251 09-02-2019, 03:00 AM
Last Post: Adam41713
  Android builds on the wiki page Bpd898kosko 1 3,773 09-02-2019, 02:53 AM
  Android 9.0 Playstore? bangity 0 2,384 08-08-2019, 06:09 PM
Last Post: bangity
  How do i compile the android SDK 9.0? restful7 0 2,438 07-31-2019, 11:38 PM
Last Post: restful7
