where is static IP addr?
to literally answer your question:
i do not know where networkmanager stores these settings.
but you are right, they are not in the "low-level" config files.
however...
(10-06-2017, 12:14 AM)skipper Wrote: I do most work via putty, but was not able to setup the fixed IP there.
you mean command line?
networkmanager has a command line interface, accessible with
nmcli
and
nmtui
iirc.
hope this helps.
where is static IP addr? - by skipper - 10-06-2017, 12:14 AM
RE: where is static IP addr? - by dkryder - 10-06-2017, 04:30 AM
RE: where is static IP addr? - by skipper - 10-06-2017, 07:31 AM
RE: where is static IP addr? - by dkryder - 10-06-2017, 08:39 AM
RE: where is static IP addr? - by skipper - 10-06-2017, 09:44 AM
RE: where is static IP addr? - by rontant - 10-06-2017, 09:14 PM
RE: where is static IP addr? - by dahni - 10-06-2017, 11:41 AM
RE: where is static IP addr? - by skipper - 10-06-2017, 11:50 AM
RE: where is static IP addr? - by skipper - 10-06-2017, 11:47 PM
RE: where is static IP addr? - by stuartiannaylor - 10-07-2017, 05:04 AM
RE: where is static IP addr? - by skipper - 10-07-2017, 07:32 AM
RE: where is static IP addr? - by stuartiannaylor - 10-07-2017, 07:00 PM
RE: where is static IP addr? - by freebsd - 10-19-2017, 06:40 AM
RE: where is static IP addr? - by skipper - 10-15-2017, 11:55 PM
Question stretch-minimal with static IP and GUI RDC skipper 1 2,645 11-24-2017, 03:45 PM
Last Post: dontpostalot
