Compatible LCD DSI
(10-06-2017, 05:05 AM)dkryder Wrote: the part about being able to use that info for pinout data i would think is ok.         by that i mean lacking any other sources of info i have used that datasheet. but even then in baby steps at a time.  i have some hardware data pin extenders for that cable because at one time i wanted to try and swap over some of those lines to fit another panel. and i started with the power cause without it you can do little else and if i'm wrong then the experiment ends right there.  you can check continuity with a multi-meter. if you have a scope or dc power supply then at lower voltages that may not damage the hardware.  anyway, if tllim put up the datasheet then i would hope the pinout is correct. i did not do any damage to my stuff. however, i had to put the project on the back burner and have not started up yet.
There is no LCD model or vendor changed and the datasheet was released from vendor.
Compatible LCD DSI - by drock - 10-02-2017, 10:42 PM
RE: Compatible LCD DSI - by dkryder - 10-03-2017, 12:44 AM
RE: Compatible LCD DSI - by drock - 10-03-2017, 12:00 PM
RE: Compatible LCD DSI - by dkryder - 10-03-2017, 08:35 PM
RE: Compatible LCD DSI - by drock - 10-05-2017, 09:49 PM
RE: Compatible LCD DSI - by dkryder - 10-06-2017, 05:05 AM
RE: Compatible LCD DSI - by tllim - 10-11-2017, 01:02 AM
RE: Compatible LCD DSI - by desai_amogh - 12-12-2017, 02:42 AM
RE: Compatible LCD DSI - by drock - 12-20-2017, 03:51 AM
RE: Compatible LCD DSI - by tllim - 12-21-2017, 12:39 PM
RE: Compatible LCD DSI - by ricoli - 12-25-2017, 11:25 AM
RE: Compatible LCD DSI - by tllim - 12-25-2017, 03:34 PM
RE: Compatible LCD DSI - by drock - 12-26-2017, 02:23 PM
RE: Compatible LCD DSI - by desai_amogh - 01-09-2018, 04:15 AM
RE: Compatible LCD DSI - by tllim - 01-09-2018, 08:05 PM
RE: Compatible LCD DSI - by drock - 01-11-2018, 02:11 AM
RE: Compatible LCD DSI - by dkryder - 01-09-2018, 07:08 PM
RE: Compatible LCD DSI - by desai_amogh - 01-09-2018, 10:40 PM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 03:15 AM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 04:53 AM
RE: Compatible LCD DSI - by drock - 01-11-2018, 08:01 PM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 11:43 PM
  Search Compatible 10.1" touchscreen alfredo78 0 3,254 07-06-2018, 03:48 AM
Last Post: alfredo78
  8inch display compatible to FY07024DI26A30-D mbt28 0 3,406 01-26-2017, 10:07 AM
Last Post: mbt28
