Compatible LCD DSI
the part about being able to use that info for pinout data i would think is ok. by that i mean lacking any other sources of info i have used that datasheet. but even then in baby steps at a time. i have some hardware data pin extenders for that cable because at one time i wanted to try and swap over some of those lines to fit another panel. and i started with the power cause without it you can do little else and if i'm wrong then the experiment ends right there. you can check continuity with a multi-meter. if you have a scope or dc power supply then at lower voltages that may not damage the hardware. anyway, if tllim put up the datasheet then i would hope the pinout is correct. i did not do any damage to my stuff. however, i had to put the project on the back burner and have not started up yet.
Compatible LCD DSI - by drock - 10-02-2017, 10:42 PM
RE: Compatible LCD DSI - by dkryder - 10-03-2017, 12:44 AM
RE: Compatible LCD DSI - by drock - 10-03-2017, 12:00 PM
RE: Compatible LCD DSI - by dkryder - 10-03-2017, 08:35 PM
RE: Compatible LCD DSI - by drock - 10-05-2017, 09:49 PM
RE: Compatible LCD DSI - by dkryder - 10-06-2017, 05:05 AM
RE: Compatible LCD DSI - by tllim - 10-11-2017, 01:02 AM
RE: Compatible LCD DSI - by desai_amogh - 12-12-2017, 02:42 AM
RE: Compatible LCD DSI - by drock - 12-20-2017, 03:51 AM
RE: Compatible LCD DSI - by tllim - 12-21-2017, 12:39 PM
RE: Compatible LCD DSI - by ricoli - 12-25-2017, 11:25 AM
RE: Compatible LCD DSI - by tllim - 12-25-2017, 03:34 PM
RE: Compatible LCD DSI - by drock - 12-26-2017, 02:23 PM
RE: Compatible LCD DSI - by desai_amogh - 01-09-2018, 04:15 AM
RE: Compatible LCD DSI - by tllim - 01-09-2018, 08:05 PM
RE: Compatible LCD DSI - by drock - 01-11-2018, 02:11 AM
RE: Compatible LCD DSI - by dkryder - 01-09-2018, 07:08 PM
RE: Compatible LCD DSI - by desai_amogh - 01-09-2018, 10:40 PM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 03:15 AM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 04:53 AM
RE: Compatible LCD DSI - by drock - 01-11-2018, 08:01 PM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 11:43 PM
  Search Compatible 10.1" touchscreen alfredo78 0 3,254 07-06-2018, 03:48 AM
Last Post: alfredo78
  8inch display compatible to FY07024DI26A30-D mbt28 0 3,406 01-26-2017, 10:07 AM
Last Post: mbt28
