Mount a HeatSink on the Rock64 using 3M Thermal Tapes
(12-02-2017, 02:50 PM)Shak7 Wrote:
(12-02-2017, 12:30 PM)Shak7 Wrote:
(11-08-2017, 02:00 PM)elatllat Wrote: What's the SOC temperature with the official heatsink under full load?
(like immediately after make -j 4 on the kernel)
The temp cut off for RK3328 SOC is 120C. It's from the manual. From my tests.. I never got more than 80C using Xenial mate image and lots of things rolling, even a chess engines tournament. I get to 100% cpu and fully used RAM for almost 5 hours non stop  and never got near of cut off temp (120C).. I find putting thermal stuff on my Rock64 4GB RAM is pretty much only for aesthetics.
I tried with a small 40x40x10mm 5V fan right on top of SOC and get -10C. Yes the fan is a nice add on but not required. At first I was thinking trying it.. Maybe the cpu would perform better, but it's not the case at all.
Are you sure the reason it's not going over 80 is that it throttles at 80?  I am running Armbian and find the CPU throttles from 1296 down to 1200 or even 1008 when running cpuburn burnCortexA9 and the temp hits about 81.
Running other apps that generate full load it hovers around 79 and does not throttle.  Only cpuburn causes throttling.
I am using the factory heatsink.
RE: Mount a HeatSink on the Rock64 using 3M Thermal Tapes - by dantheperson - 02-19-2018, 08:43 PM
  Are HW design files available for ROCK64? irenek 3 5,060 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 349 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,097 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 635 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,328 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,786 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,549 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,658 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,631 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,102 09-28-2021, 03:07 PM
Last Post: TRS-80
