Network service discovery disabled
(08-18-2017, 10:10 PM)Siliconserf Wrote: ...  even though I'm logged in as a user with administrator privilege, the editor won't save, complaining that I don't have the necessary privilege. Is it necessary to invoke a particular program from a command line?
Administrator privileges give you specific rights like the ability to use the sudo command, because your administrator id is in the sudoers file.  Try this :
sudo  vi  <path/filename>
or
sudo  gedit   <path/filename>
or
sudo  nano  <path/filename>
hint:  the sudo command gives you temporary root privileges  ::  it will prompt you for your password !
RE: Network service discovery disabled - by MarkHaysHarris777 - 08-19-2017, 12:53 AM
