CONFIG_IP_NF_NAT
(08-16-2017, 06:55 PM)nebbors Wrote:
(08-16-2017, 05:15 PM)MarkHaysHarris777 Wrote:
(08-15-2017, 07:59 PM)nebbors Wrote: Need module? Do I need to recompile myself or is it easier than that?
Your question is too vague.
... are we talking about a Python module ( sometimes VERY easy )?
... are we talking about a kernel module ( sometimes extremely difficult )?
... or perhaps we're discussing a C module ( usually easy and almost always automated )?
good point. kernel module required for a docker compile.
You will need the kernel header files for sure;  if the module (name?) support has already been added to the kernel you can compile the module source and then put the module blahblah.so in the /lib directory, and then insmod it;  however,  if the module support is NOT in the kernel yet , you will also need to recompile the kernel ( a pain in the arse but doable ) and then decide whether to statically link it, or insmod it.
Some of this depends on your skill set too...
CONFIG_IP_NF_NAT - by nebbors - 08-15-2017, 07:59 PM
RE: CONFIG_IP_NF_NAT - by nebbors - 08-16-2017, 04:44 PM
RE: CONFIG_IP_NF_NAT - by MarkHaysHarris777 - 08-16-2017, 05:15 PM
RE: CONFIG_IP_NF_NAT - by nebbors - 08-16-2017, 06:55 PM
RE: CONFIG_IP_NF_NAT - by MarkHaysHarris777 - 08-16-2017, 07:14 PM
