height between stock heatsink and bottom
(08-13-2017, 02:19 PM)schepers_cp Wrote: the teardown doesn't give any more info than you said in your response, which isn't much either to be honest, i basically need the minimal height that is available (in whole mm is good enough for me)
Hard to measure but approx. 1 - 1.3mm.
edit: perhaps a bit more than that. The bottom portion of the case is not uniform, so its thicker in some places than others.
RE: height between stock heatsink and bottom - by Luke - 08-13-2017, 03:43 PM
