java crashes
(07-03-2017, 09:49 AM)Erik Wrote: Sickofthesea, you did install the latest and greatest Mate from the website, did'nt you? On my pinebook since the upgrade jave runs just fine.
If only I knew how to post a screen shot on this forum i can show you my running jedit
5,3 I installed on it by
'apt install jedit'
[Image: screenshot.png]
Erik
Delft
PS: I just figured out how to add pictures, it is a bit clumpsy, but it works...
My spanking new SD of 0.5.5.65 runs like a charm, and I'm using dear old jedit happily. Thanks for the solution, Erik.
Jared
java crashes - by Erik - 06-22-2017, 06:18 AM
RE: java crashes - by MarkHaysHarris777 - 06-22-2017, 08:01 AM
RE: java crashes - by Erik - 06-22-2017, 01:09 PM
RE: java crashes - by xalius - 06-22-2017, 02:42 PM
RE: java crashes - by dkryder - 06-22-2017, 04:15 PM
RE: java crashes - by Erik - 06-23-2017, 03:38 AM
RE: java crashes - by sickofthesea - 07-03-2017, 05:46 AM
RE: java crashes - by dkryder - 07-03-2017, 06:35 AM
RE: java crashes - by Erik - 07-03-2017, 09:49 AM
RE: java crashes - by JaredF - 07-23-2017, 08:01 PM
RE: java crashes - by pfeerick - 07-24-2017, 12:08 AM
