(06-03-2017, 12:25 PM)stephen fleming Wrote: Let's start for the beginning. I started out using Ubuntu Mate for the SOpine and tried to set it up to use the 7" touch screen by modifying the uEnv.txt file. When I opened the file, the contents were not the same as in the thread I was using to modify the file. I was later told in the thread I referenced that the official Ubuntu image for the SOpine did not have LCD support yet. It was later brought up that Armbian had support for the LCD and there was a suggestion to use Armbian. That is the reason that I switched to using Armbian, which seems to have solved one problem and created another one.ya know, because i'm getting tired of bluetooth on armbian i went to the forum and read the notes they provide and it states that bluetooth is not supported out of the box. so good luck, i'm done. if you would just read what's there you might not jump down rabbit holes and then ask for help to get out of the rabbit holes so often. when it is completely unnecessary.
