06-15-2016, 04:11 PM
(This post was last modified: 06-15-2016, 04:35 PM by texadactyl.)
(04-23-2016, 04:21 PM)baryluk Wrote: Hey thanks! The key package was boinc-app-seti which shows up in the package catalogue using synaptics but not visible using dpkg -l *UNTIL* you install it! Now, if we can only get the other boinc apps (E.g. pogs) to do the same.
By the way, boinc-manager (GUI) works just fine as it is the same version as boinc-client i.e. 7.6.31.
I do not yet have a heat sink.
Not over-clocked.
With 4 busy cores, I observed a steady temperature of 90C (ouch!).
I backed off to 2 busy cores and observe the temperature steady in the 60-70C range.
A heat sink is a good idea!
