IR Receiver
(06-17-2016, 09:40 AM)bcommando Wrote:
(06-17-2016, 09:29 AM)xalius Wrote:
(06-17-2016, 09:05 AM)bcommando Wrote: Hi! Can someone show me an image of the remote sensor installed? I see where I think it should be soldered from the image above but I am not 100% sure. Thanks for your help!
Hi, did you see http://wiki.pine64.org/images/7/7d/Pine6...nector.png ? No need to solder, there is a 3x1 header where you can stick the IR receiver, as for the pinout, it is describe in the schematic and/or in http://wiki.pine64.org/images/d/da/Pine64_Connector.JPG. I just mounted mine facing outwards and trying to see if I can get it working with Linux...
I did not see that! Thank you very much! That is very helpful!
Did you cut length ofthe IR receiver? It looks as if there isn't enough room for the top (with the risers on) to be on?
I inserted the receiver facing OUT and it worked immediately with Android and Kodi.
IR Receiver - by hrh1818 - 02-22-2016, 01:58 PM
RE: IR Receiver - by MichaelMeissner - 02-22-2016, 02:12 PM
RE: IR Receiver - by tllim - 02-22-2016, 10:51 PM
RE: IR Receiver - by hrh1818 - 02-25-2016, 01:00 PM
RE: IR Receiver - by tllim - 02-25-2016, 07:15 PM
RE: IR Receiver - by RogerioNeiva - 05-15-2016, 06:36 AM
RE: IR Receiver - by hazerty - 05-15-2016, 06:43 AM
RE: IR Receiver - by bcommando - 06-17-2016, 09:05 AM
RE: IR Receiver - by xalius - 06-17-2016, 09:29 AM
RE: IR Receiver - by bcommando - 06-17-2016, 09:40 AM
RE: IR Receiver - by RogerioNeiva - 06-17-2016, 12:10 PM
RE: IR Receiver - by tiagomr - 06-22-2016, 11:10 AM
RE: IR Receiver - by xalius - 06-17-2016, 12:09 PM
RE: IR Receiver - by xalius - 06-22-2016, 11:15 AM
  Can the Pine64 act as a bluetooth receiver? photojoe 7 10,080 11-04-2019, 02:26 AM
Last Post: Partymack711
