overlapping partitions issue with resize of 8GB image put on 16GB sd card
(09-23-2016, 12:03 PM)dkryder Wrote: i put an android 5.1 dd image,
dd bs=4M if=/home/dkryder/Downloads/pine64/pine64-lollipop-beta-2-lcd-dd-8.img of=/dev/mmcblk0
it boots and runs fine. i would like to recover the unused space and add to the image. using gparted i get an error message about overlapping partitions. fdisk gives me this,
 sudo fdisk -l /dev/mmcblk0
[sudo] password for dkryder:
omitting empty partition (14)
Disk /dev/mmcblk0: 16.0 GB, 16021192704 bytes
1 heads, 16 sectors/track, 1955712 cylinders, total 31291392 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x8b83061f
        Device Boot      Start         End      Blocks   Id  System
/dev/mmcblk0p1         5251072    15194110     4971519+   b  W95 FAT32
/dev/mmcblk0p2   *       73728      139263       32768    6  FAT16
/dev/mmcblk0p3               1     5251072     2625536   85  Linux extended
/dev/mmcblk0p5          139264      172031       16384   83  Linux
/dev/mmcblk0p6          172032      204799       16384   83  Linux
/dev/mmcblk0p7          204800     3350527     1572864   83  Linux
/dev/mmcblk0p8         3350528     3383295       16384   83  Linux
/dev/mmcblk0p9         3383296     3448831       32768   83  Linux
/dev/mmcblk0p10        3448832     5021695      786432   83  Linux
/dev/mmcblk0p11        5021696     5054463       16384   83  Linux
/dev/mmcblk0p12        5054464     5087231       16384   83  Linux
/dev/mmcblk0p13        5087232     5251071       81920   83  Linux
Partition table entries are not in disk order
i can see what i think might be the problem but having never been in the situation i'm not sure what to do.  i found this page,
http://gparted.org/h2-fix-msdos-pt.php#o...partitions
i could use some help in what changes i need to make. thanks
What burn tool did you use to burn the image?
RE: overlapping partitions issue with resize of 8GB image put on 16GB sd card - by Bluphire - 10-03-2016, 09:11 AM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,633 05-19-2023, 07:43 AM
Last Post: crocspot
Exclamation Can't boot when SD card inserted kivox 5 8,097 03-15-2020, 06:00 AM
Last Post: kivox
Photo Daughter Card SBC for P64 blue 5 7,121 08-22-2017, 07:51 AM
Last Post: blue
  Pine64 $15 card killed my $120 keyboard exa 22 27,847 01-04-2017, 09:01 AM
Last Post: skenn_ie
  Rooted Android LCD 64GB Image modsbyus 3 5,151 09-17-2016, 03:00 PM
Last Post: echild
  SD card recovery TeaPack 8 8,769 08-07-2016, 07:35 AM
Last Post: xalius
  Can't write to SD card w/ Adapter apple4ever 2 4,325 07-23-2016, 03:16 PM
Last Post: apple4ever
  missing SD card xj-boonie 4 5,678 07-13-2016, 12:22 PM
  128GB Card OS? mesaxi 12 16,766 07-12-2016, 11:59 PM
Last Post: Tarjei85
  Problem making SD card Tam Dl 17 20,510 06-19-2016, 07:48 PM
Last Post: pfeerick
