01-28-2016, 07:28 AM
(01-28-2016, 07:11 AM)taros Wrote: The dimensions of the A64 (the SoC) are 15mm x 15mm. There is enough clearance for up to about 20mm x 20mm.
The dimensions of the voltage regulator are 9mm x 9mm.
You can buy 15mm x 15mm heatsinks for cheap. Some come with adhesive tape.
See http://www.michaeldornisch.com/2012/06/d...-sink.html on how to may your own tiny heatsinks.
Requires tools to cut a bigger heatsink to smaller ones.
They got a reduction in temperature of about 18C.
Thanks! I have this old laptop with a small fan, i think i'll be doing the DIY way.
If I've helped you with something, please leave a rating for my responses.
