Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation
In the pic above I am powering the PineA64 with a 12v batt (3000mah, SLA) using the 'CPT Car Power Technology' DC-DC converter;  it takes input of 7v - 50v (10 Watt) and has an output of 5v @ 2000ma.
Again, I am feeding the 5v out from the DC-DC converter through the PI  low_pass  filter;  this is important when using most DC-DC converters, because they typically produce noisy outputs.  The PI filter will reduce the noise on the DC line input to the PineA64 producing a nice clean quiet stable power source!
Note: CPT comes with a micro usb connector output; I removed the connector-- I was pleased to find a good two wire cable under the sheath and I decided to feed the power to the euler bus +5v to pin(4) and the ground wire negative to pin(6). This makes the connection 'solid' and by-passes the weak micro usb connection. This is preferred for most robotics applications.
This is the solder side of the PI filter board. The important thing to note is that it is simplicity itself. Anybody can do this !
This is a close-in of the finished PI filter.  The point to note here is the male header pins. I always build small projects like this with header pins so that setup and tear-down is easy with jumper wires; also the same component can be swapped in when needed in other projects.
Update: I added two close-in pics of the PI filter.
... again, this very much a beginner soldering project; just dive in and try it !
RE: Alternate Power DC-IN on the Euler Bus - by MarkHaysHarris777 - 08-12-2016, 04:34 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,129 07-03-2021, 01:29 AM
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,546 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,424 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,914 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,408 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,794 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,989 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,461 01-07-2017, 11:59 PM
Last Post: aegrotatio
  Correct Voltage For Powering From Euler?? thisrestricted 7 11,362 10-18-2016, 06:49 PM
Last Post: veronicasmithen03
  First cable for Euler Bus power done! AVL2016 24 33,430 10-05-2016, 06:43 AM
Last Post: Ghost
