connect lipo battery to euler bus
(09-10-2016, 02:55 PM)MarkHaysHarris777 Wrote:
(09-10-2016, 03:39 AM)pfeerick Wrote: So there is definitely  something odd going on here... can you confirm if this is with the pine64 on or off, how it's powered, and which you're using? I'm starting to wonder if the PMIC on this board is a bit flaky... as there doesn't seem to be any good reason for it to be running so. Then again, datasheet isn't the best on some points - it doesn't detail what the charge 'smarts' of the PMIC is, if this one has any at all. It seems to indicate it only follows a CC/CV profile, with over-voltage/over-temp protection.
hi, I am presently running my Android batt to the ground ... then I'll start a change cycle and see what I can see by looking in sysfs.
I can do that same thing for my debian build too, as far as that goes.
I'm sorry, I'll repeat the question: Can you confirm if this is with the pine64 on or off, how it's powered, and which distro you're using?
I gather from you you just said that this might be on Android... is that correct? This would explain a lot of things (specifically, why registers might have been reconfigured from their defaults).
RE: connect lipo battery to euler bus - by pfeerick - 09-10-2016, 06:40 PM
RE: connect lipo battery to euler bus - by peteh - 09-10-2016, 02:51 PM
  +LTS/SOPINE +PINEBOOK configuring Euler Bus pin generate interrupt RANJITT76 0 2,465 01-10-2019, 02:45 AM
Last Post: RANJITT76
  Mapping Euler bus DC in and 5v DC out pins g_t_j 8 10,622 07-02-2016, 09:30 PM
Question What exactly is a Euler Bus? Ghost 10 37,881 05-06-2016, 06:49 PM
  Euler Bus hrh1818 4 13,962 01-29-2016, 01:56 PM
