Replacement screen disconnects after back frame is screwed on
I cracked my (original) Pinephone screen and got a replacement. Installation seemed ok, and I snapped the back frame on and put in the battery to make sure everything was ok. Booted, unlocked, logged in, great.
So I replaced the 15 screws and snapped the back cover on for more testing, and after a short while, the screen wouldn't wake up. I plugged it in to my computer USB, and the pinephone was recognized, so it's running, motherboard working, daughterboard working, just no display. I assumed I made a bad connection and disassembled and detached, cleaned, and re-attached the display cable. Snapped the back frame back on and put in the battery and all was fine.
Again, I replaced the screws and rechecked. Now the screen doesn't seem to unlock. On a very close look, it seems the backlight comes on but the display itself isn't responding.
Repeating the process, everything seems to work, including the display, until I install the back frame screws. WTH am I doing wrong here? I don't think I'm over-tightening the screws -- I don't even know why that would be a problem.
What's going on here? Why does the screen work until I screw down the back frame? What do I need to do to get my phone up and running while fully assembled?
Ideas? Thanks!
Replacement screen disconnects after back frame is screwed on - by robthebold - 09-25-2023, 09:02 PM
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 406 12-28-2023, 01:26 PM
Last Post: bedtime
Question Alternative Designs or Materials for the Back Cover? BMayes 2 602 12-18-2023, 11:19 AM
Last Post: BMayes
  Pinephone frame damages Uturn 2 1,035 10-23-2023, 02:49 AM
Last Post: Uturn
  Screen dying already? marcih 153 147,749 02-23-2023, 04:14 AM
Last Post: Shatur
  Screen Replacement Instructions erikkugel 4 3,224 09-07-2022, 11:04 PM
Last Post: RTP
  Microphone replacement SocialNetworkingWasAMistake 1 1,575 08-05-2022, 03:16 PM
Last Post: calinb
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,720 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 1,789 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 4,086 03-08-2022, 12:25 PM
Last Post: jopple
  How hard to replace screen? Zebulon Walton 28 29,657 01-18-2022, 12:21 AM
Last Post: henrythemouse
