Couple of problems updating
(08-06-2023, 02:08 AM)Ctrl_Amiga_1070 Wrote:
(07-28-2023, 09:22 PM)Kevin Kofler Wrote:
(07-26-2023, 07:06 PM)Ctrl_Amiga_1070 Wrote: Si I have purchased the pro 64 version, don't remember in its explorer pro or what. I have searched for "how to identify" which hardware modle i have but haven't found anything to confirm.
If it is a PinePhone Pro, it is almost certainly the Explorer Edition. There have been no other widely distributed versions yet.
(07-26-2023, 07:06 PM)Ctrl_Amiga_1070 Wrote: Problem 1. Whenever "power" is connected (Battery or usb) it boots
Problem 2. No matter what I do, I cannot "shut down", it just boots again
That it boots if you newly plug in a power source is considered a feature, not a bug. My original PinePhone also does that. I am not aware of any way to turn that off. But it should not boot just because you have a power source already plugged in.
(07-26-2023, 07:06 PM)Ctrl_Amiga_1070 Wrote: Problem 3. cant connect adb to device.
That is because the PinePhone does not use adb. (The modem chip does, internally, but that is only relevant if you want to upgrade or replace the modem firmware. The main CPU uses uBoot/Tow-Boot as bootloaders, not fastboot, so it cannot be used with Android tools.)
(07-26-2023, 07:06 PM)Ctrl_Amiga_1070 Wrote: Sort of problem. I've tried Power + vol-down & Power and RE button, as per instructions to get device into fastboot mode.
Is my device in fastboot mode or some other mode?
That puts the device into Tow-Boot's USB mass storage mode. There is no fastboot mode, because Tow-Boot is not fastboot. Fastboot is the Android bootloader.
(07-26-2023, 07:06 PM)Ctrl_Amiga_1070 Wrote: I finally managed it, just now (why I am starting this thread) I think into fastboot mode. I have a permanent BLUE led, with usb cable connected to LINUX. However I can see two (2) new devices on my Linux PC.
BOOT_MNJRO
ROOT_MNJRO
I have access to both of these.
What do I do, Please?
Those are the 2 partitions on your phone's eMMC. You can mount them, but if you want to install a new OS, you will want to instead flash an image onto the entire eMMC, not mount the preexisting partitions on it.
See: https://wiki.pine64.org/wiki/PinePhone_P...o_the_eMMC
Thanks !
But I've read that like 50 times. Still does NOT explain do I dd write to
BOOT_MNJRO
or
ROOT_MNJRO
or
BOTH ?? I may not have been clear, and the instructions are any but.
 you mean step 7 ?
 it says "device" not partition
 ezik
Couple of problems updating - by Ctrl_Amiga_1070 - 07-26-2023, 07:06 PM
RE: Couple of problems updating - by mikehenson - 07-27-2023, 07:41 AM
RE: Couple of problems updating - by Kevin Kofler - 07-28-2023, 09:22 PM
RE: Couple of problems updating - by shulamy - 08-06-2023, 04:45 AM
RE: Couple of problems updating - by shulamy - 08-11-2023, 08:51 AM
  Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability ArchiMark 4 1,539 05-28-2023, 07:00 AM
Last Post: ArchiMark
  Error Updating Emilio 2 2,227 02-20-2022, 09:51 AM
Last Post: Emilio
  Still having problems w. Calls app - Speaker Phone not usable iwm 3 2,486 01-06-2022, 08:14 PM
Last Post: bcnaz
