pinephone keyboard + dock question
(01-26-2023, 12:10 AM)tuxcall Wrote:
(01-25-2023, 04:49 PM)emsyr Wrote:
(01-24-2023, 11:48 AM)tuxcall Wrote: Hi!
i've recently gotten the pinephone keyboard
now i also have the dock that came with the pinephone.
The manual of the pinephone keyboard states to NOT charge through the pinephone usb port and only through  the keyboards usb charging port.
to use the dock you need to use the pinephone's usb and connect the charger to the dock. Which to me would be charging through the pinephone.
Which the manual warns against.
can you use the dock + the pinephone keyboard together or is this impossible?
I think you should charge through the keyboard's usb-c port and connect your dock in Pinephone's usb-c port to connect your peripheral devices.
In keyboard's manual it's written that:
Quote:You should charge the PinePhone and the keyboard only using the USB-C port on the keyboard. The keyboard’s USB-C port cannot be used for peripherals. The PinePhone’s USB-C port remains operational when mounted in the keyboard and can be used for data and peripherals.
I had already tried that (tried it again just now), but that didn't seem to work. no display on the hdmi and UI nor tweaks does not show a connected dock,
i have the suspicion the dock needs direct power to function
Have you tested whether the dock is operational without the keyboard attached and without power supply as well? If it is not functioning, it may be a verification of your suspicion. I have done a quick search on the internet but I'm not finding any info about what you are looking for. You may also experiment with different distros.
pinephone keyboard + dock question - by tuxcall - 01-24-2023, 11:48 AM
RE: pinephone keyboard + dock question - by emsyr - 01-25-2023, 04:49 PM
RE: pinephone keyboard + dock question - by emsyr - 01-27-2023, 01:40 PM
RE: pinephone keyboard + dock question - by wigan - 02-03-2024, 02:53 PM
RE: pinephone keyboard + dock question - by wigan - 02-05-2024, 03:17 PM
  Updated Physical Keyboard? jakfish 0 18 10 hours ago
Last Post: jakfish
  my pinephone melted norayr 6 826 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,079 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  quick question about mic Ferriah 3 332 03-23-2024, 02:11 PM
  various tricks to open the pinephone shengchieh 2 703 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 337 03-21-2024, 08:52 AM
Last Post: unrznbl
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,753 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,386 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 980 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,109 08-23-2023, 03:25 AM
Last Post: Kali
